Hello, so after today's update of aapanel (i'm using almalinux 8.9) the bt service and bt task are not starting, also when using any bt - number - commands, they are not working.
Successfully upgraded to[7.0.2]
[root@vmi1602301 ~]# bt restart
Stopping Bt-Tasks... done
Stopping Bt-Panel... done
Starting Bt-Panel............failed
from ..globals import current_app
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/globals.py", line 4, in <module>
from werkzeug.local import LocalProxy
ModuleNotFoundError: No module named 'werkzeug'
File "/www/server/panel/BT-Panel", line 10, in <module>
from gevent import monkey
ImportError: No module named gevent
done
Starting Bt-Tasks... failed
from psutil import Process, pids, cpu_count, cpu_percent, net_io_counters, disk_io_counters, virtual_memory
ImportError: No module named psutil
File "/www/server/panel/BT-Task", line 13, in <module>
import task
File "/www/server/panel/task.py", line 19, in <module>
import task
import task
Before uprading the panel everything worked just fine. Tried to reinstall it:
[root@vmi1602301 ~]# rm -rf /www/server/panel/pyenv/
[root@vmi1602301 ~]# curl http://download.bt.cn/install/update6_en.sh|bash
Same problem.
Also when running any bt <number> command, I get this:
[root@vmi1602301 ~]# bt 1
File "/www/server/panel/tools.py", line 20, in <module>
import public,time,json
File "/www/server/panel/class/public/init.py", line 969
def GetNumLines(path, num: int, p=1):
SyntaxError: invalid syntax
[root@vmi1602301 ~]# bt 16
Thanks
