aaPanel_Kern Hello, please check if the web program is running normally? Is port 888 listening? You can check it in the security interface firewall. At the same time, the server provider’s firewall needs to open port 888. aaP_tacpawar
aaPanel_Kern Hello, is it normal to restart nginx using the command? If there is any error information please provide it /etc/init.d/nginx restart aaP_tacpawar
