Hi, I have having a problem for a couple of weeks now. MySQL service stops automatically at least 2-3 times a week. Can anyone help me checking the logs below?
2024-05-24T23:52:25.587463Z 0 [Warning] [MY-000081] [Server] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824.
2024-05-24T23:52:25.591006Z 0 [Warning] [MY-010915] [Server] 'NO_ZERO_DATE', 'NO_ZERO_IN_DATE' and 'ERROR_FOR_DIVISION_BY_ZERO' sql modes should be used with strict mode. They will be merged with strict mode in a future release.
2024-05-24T23:52:25.598810Z 0 [System] [MY-010116] [Server] /www/server/mysql/bin/mysqld (mysqld 8.0.24) starting as process 175409
2024-05-24T23:52:25.965825Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2024-05-24T23:52:27.449072Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2024-05-25T06:48:23.692967Z 0 [Warning] [MY-000081] [Server] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824.
2024-05-25T06:48:23.695416Z 0 [Warning] [MY-010915] [Server] 'NO_ZERO_DATE', 'NO_ZERO_IN_DATE' and 'ERROR_FOR_DIVISION_BY_ZERO' sql modes should be used with strict mode. They will be merged with strict mode in a future release.
2024-05-25T06:48:23.697950Z 0 [System] [MY-010116] [Server] /www/server/mysql/bin/mysqld (mysqld 8.0.24) starting as process 182541
2024-05-25T06:48:23.928022Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2024-05-25T06:48:25.087316Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2024-05-25T06:48:25.641642Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Bind-address: '::' port: 33060, socket: /tmp/mysqlx.sock
2024-05-25T06:48:26.053719Z 0 [System] [MY-010229] [Server] Starting XA crash recovery...
2024-05-25T06:48:26.088862Z 0 [System] [MY-010232] [Server] XA crash recovery finished.
2024-05-25T06:48:26.278841Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
2024-05-25T06:48:26.279143Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
2024-05-25T06:48:26.326979Z 0 [System] [MY-010931] [Server] /www/server/mysql/bin/mysqld: ready for connections. Version: '8.0.24' socket: '/tmp/mysql.sock' port: 3306 Source distribution.
