aaPanel_Jose Change Log: Add [Terminal] page to provide multi-terminal support. Cancel the compatibility of communication encryption with Python 2.x. Allow the database to recover data from cloud storage. Cut the log together with the error log when cron cuts the log.
aaPanel_Jose KrzysztofMaciejewski Clicking on the Fix panel will automatically restore to the stable version, I just tested that the updated version is indeed 6.9.11
Jimmy @aaPanel_Jose I just install aapanel and I have the 6.8.2 version. How I can change to beta version? Do you provide new installation command to separate the beta and stable version?
KrzysztofMaciejewski it is save to update Centos 8.2 with "sudo yum update ???" i have 160 mb of updates after update to AApanel 6.8.2: @aaPanel_Jose what you think?
