aaPanel_Kern Hi, please check if you are using the full link to access the panel, you can use the command to view bt 14 aaP_tacpawar
aaPanel_Kern Hello, please hide personal information. Do you want to set up a restricted IP? Do you want to set up a bound domain name? You can use the bt command to cancel aaP_tacpawar
aaPanel_Kern After binding the domain, you need to use the domain name to access the panel, and you cannot use IP to access the panel. aaP_tacpawar
aaPanel_Kern Hi, would you like to check if there are any restrictions? You can use the bt command to remove the restriction aaP_tacpawar
