aaP_mediadigitalxxi
i see this
root@mxxx:~# curl -k https://www.aapanel.com/script/aapanel_check.sh | bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 5818 100 5818 0 0 25857 0 --:--:-- --:--:-- --:--:-- 25857
Bt-Panel (pid 130667) already running
Bt-Task (pid 127516) already running
Getting server ip, Please wait...
aaPanel port external network test access failed
For reference only, please test manually!
SSL is not enabled, please use HTTP access
aaPanel Internet Address: http://xx.xxx.xx.xx:32334/29ddfs
aaPanel Internal Address: http://xx.xxx.xx.xx:32334/29ddfs
When sharing, please be careful to hide your IP address
Server internal 127.0.0.1 test access failed
-------------------------Disk space usage--------------------------
Filesystem Size Used Avail Use% Mounted on
udev 34G 0 34G 0% /dev
tmpfs 6.7G 86M 6.6G 2% /run
/dev/nvme0n1p4 997G 152G 795G 17% /
tmpfs 34G 13k 34G 1% /dev/shm
tmpfs 5.3M 0 5.3M 0% /run/lock
tmpfs 34G 0 34G 0% /sys/fs/cgroup
/dev/nvme0n1p2 1.6G 156M 1.3G 11% /boot
/dev/nvme0n1p1 535M 308k 535M 1% /boot/efi
tmpfs 6.7G 0 6.7G 0% /run/user/0
--------------------------Inode usage------------------------------
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 8119650 510 8119140 1% /dev
tmpfs 8135568 903 8134665 1% /run
/dev/nvme0n1p4 61857792 545764 61312028 1% /
tmpfs 8135568 6 8135562 1% /dev/shm
tmpfs 8135568 2 8135566 1% /run/lock
tmpfs 8135568 18 8135550 1% /sys/fs/cgroup
/dev/nvme0n1p2 98304 595 97709 1% /boot
/dev/nvme0n1p1 0 0 0 - /boot/efi
tmpfs 8135568 18 8135550 1% /run/user/0
Python version: Python 3.12.3
aaPanal version_o: 7.0.2
/www/server/panel/BT-Panel:63: SyntaxWarning: invalid escape sequence '\c'
os.system("\cp -f {} {}".format(plugin_loader_src_file, plugin_loader_file))
/www/server/panel/BT-Panel:238: DeprecationWarning: setDaemon() is deprecated, set the daemon attribute instead
task_thread.setDaemon(True)
