File "/www/server/panel/class/panelPlugin.py", line 2312, in a
return public.run_plugin(get.name, get.s, get)
File "/www/server/panel/class/public/init.py", line 7952, in run_plugin
raise PanelError(res['msg'])
public.PanelError: An error occurred while the panel was running: Traceback (most recent call last):
File "/www/server/panel/plugin/pm2/pm2_main.py", line 378, in GetMod
modList = json.loads(tmp[0])
File "/www/server/panel/pyenv/lib/python3.12/json/init.py", line 346, in loads
return default_decoder.decode(s)
File "/www/server/panel/pyenv/lib/python3.12/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=w(s, 0).end())
File "/www/server/panel/pyenv/lib/python3.12/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
File "/www/server/panel/BTPanel/init.py", line 2530, in publicObject
File "/www/server/panel/BTPanel/init.py", line 2477, in run
File "/www/server/panel/class/panelPlugin.py", line 2314, in a
return public.get_error_object(None, plugin_name=get.name)
File "/www/server/panel/class/public/init.py", line 1243, in get_error_object
result = readFile('{}/BTPanel/templates/default/plugin_error.html'.format(get_panel_path())).format(
KeyError: 'plugin name'
