geyhbrd Sidebar not working Customized links in the sidebar have disappeared Custom Alias for tab bar is not working. Every time you log in, you are prompted that the software is installed,That's not necessary at all. I'm now very curious to know how to go back to the previous version, this one doesn't work at all
aaPanel_Kern Hello, thank you for your feedback, How to display the sidebar if it is not working? Temporarily removed and will be added later. Please provide the screenshot below for the specific location. Is this a newly installed panel? geyhbrd
geyhbrd aaPanel_Kern Sorry, I meant that the hide function of the panel menu bar is not in effect It's not a new install, it's an upgrade, and I've tried multiple servers and it definitely triggers the I'm more concerned about downgrading to 6.x now
aaPanel_Kern Hello, The hidden menu is a BUG and will be fixed later. Is it the same when using the browser in incognito mode or changing the browser? geyhbrd
aaPanel_Kern What version is your panel? Is it normal to try to update to the latest version? geyhbrd
