please help
after update to latest ver. the panel crashed and cannot access backend, I tried to start manually but not success please help
bt start
Starting Bt-Panel............failed
File "class/http_requests.py", line 103, in post
result = requests.post(url,data,timeout=timeout,headers=headers,verify=verify)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 115, in post
return request("post", url, data=data, json=json, **kwargs)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 59, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 589, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 703, in send
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 532, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='www.bt.cn', port=443): Read timed out. (read timeout=6)
nohup: failed to run command '/www/server/panel/BT-Panel': No such file or directory
done
Starting Bt-Tasks... failed
pypcap module install failed.
pypcap module install failed.2024-05-22 14:45:39 [INFO]: Service Up
2024-05-22 21:03:32 [INFO]: Panel Service: restart
2024-05-22 21:03:34 [INFO]: Service Up
nohup: failed to run command '/www/server/panel/BT-Task': No such file or directory
