aaPanel_Kern aaP_kc901789 Hello, please go to the monitoring interface to see what is occupying the cpu.
aaPanel_Kern Hello, you need to check the reason yourself. You can go to the monitoring interface to check the cpu occupied by the specific process or use the top command to check aaP_kc901789
aaPanel_Kern Hello, please put the mouse on the relevant chart to view the specific process, or use the top command to view it. aaP_kc901789
