Good evening,
after i updated to beta 7.0 panel is broken. I tried to reset the security string and I can access the panel, however all sites, settings, ftp everything shows an empty list!
After login into panel, it shows 404 Nginix error browsing any other pages. Panel log shows the following error. Please help
`/www/server/panel/tools.py:28: SyntaxWarning: invalid escape sequence '.'
root_mysql = '''#!/bin/bash
/www/server/panel/tools.py:70: SyntaxWarning: invalid escape sequence '\w'
re_list = re.findall("[\w\d,.]+", password)
/www/server/panel/tools.py:86: SyntaxWarning: invalid escape sequence '\c'
mysql_dir = '''#!/bin/bash
/www/server/panel/tools.py:412: SyntaxWarning: invalid escape sequence '\w'
re_list = re.findall("[\w\d,.]+", username)
EXECUTING
/www/server/panel/class_v2/panel_redirect_v2.py:429: SyntaxWarning: invalid escape sequence '{'
add_str='#REWRITE-START\n<IfModule mod_rewrite.c>\n RewriteEngine on\n RewriteCond %{REQUEST_FILENAME} !-f\n RewriteCond %{REQUEST_FILENAME} !-d\n RewriteRule . '+redirect_path+' [L'+add_type+'\n</IfModule>\n#REWRITE-END'
/www/server/panel/class_v2/panel_redirect_v2.py:687: SyntaxWarning: invalid escape sequence '\s'
rep += "#301-START\n+[\s\w:\/.\;\$]+#301-END"
/www/server/panel/class_v2/panel_redirect_v2.py:689: SyntaxWarning: invalid escape sequence '<'
rep += "#301-START[\n<>\w.\s^*\$\/[]():\,\=]+#301-END"
/www/server/panel/class_v2/site_dir_auth_v2.py:144: SyntaxWarning: invalid escape sequence '\w'
rep = "enable-php-(\w{2,5}).conf"
/www/server/panel/class_v2/site_dir_auth_v2.py:147: SyntaxWarning: invalid escape sequence '\d'
rep = "enable-php-(\d+-wpfastcgi).conf"
/www/server/panel/class_v2/site_dir_auth_v2.py:150: SyntaxWarning: invalid escape sequence '\w'
rep = "php-cgi-(\w{2,5}).sock"
/www/server/panel/class_v2/site_dir_auth_v2.py:234: SyntaxWarning: invalid escape sequence '\/'
rep = "IncludeOptional.\/dir_auth\/.conf(\n|.)+<\/VirtualHost>"
/www/server/panel/class_v2/site_dir_auth_v2.py:241: SyntaxWarning: invalid escape sequence '\s'
rep = "\n#Directory protection rules, do not manually delete\n+\s+IncludeOptional[\s\w\/.*]+"
/www/server/panel/class_v2/site_dir_auth_v2.py:246: SyntaxWarning: invalid escape sequence '\/'
rep = "#SSL-END(\n|.)+include.\/dir_auth\/.conf;"
/www/server/panel/class_v2/site_dir_auth_v2.py:251: SyntaxWarning: invalid escape sequence '\s'
rep = "\n#Directory protection rules, do not manually delete\n+\s+include[\s\w\/.*]+;"
/www/server/panel/class_v2/site_dir_auth_v2.py:394: SyntaxWarning: invalid escape sequence '\s'
if re.search('\s', password):
/www/server/panel/class_v2/site_dir_auth_v2.py:404: SyntaxWarning: invalid escape sequence '\s'
if re.search('\s', username):
/www/server/panel/class_v2/site_dir_auth_v2.py:414: SyntaxWarning: invalid escape sequence '\s'
if re.search('\s', name):
/www/server/panel/class_v2/site_dir_auth_v2.py:416: SyntaxWarning: invalid escape sequence '\/'
if re.search('[\/\"\'!@#$%^&()+={}[]:\;\?><,./\]+', name):
/www/server/panel/class_v2/one_key_wp_v2.py:77: SyntaxWarning: invalid escape sequence ':'
_ajax_nonce_rep = '"ajax_nonce\\":\\"(\w+)'
/www/server/panel/class_v2/one_key_wp_v2.py:274: SyntaxWarning: invalid escape sequence '\s'
if not re.search('127.0.0.1\s+{}'.format(values['site_name']), hosts):
/www/server/panel/class_v2/one_key_wp_v2.py:366: SyntaxWarning: invalid escape sequence '\s'
wp_nonce_rep = '"wpnonce\\"\svalue=\\"(\w+)'
/www/server/panel/class_v2/one_key_wp_v2.py:418: SyntaxWarning: invalid escape sequence '\s'
smart_http_expire_form_nonce = '"smart_http_expire_form_nonce\\"\svalue=\\"(\w+)'
/www/server/panel/class_v2/one_key_wp_v2.py:588: SyntaxWarning: invalid escape sequence '\$'
version = re.search('\$wp_version\s=\s[\'\"]{1}([\d.])[\'\"]{1}', conf).groups(1)[0]
/www/server/panel/class_v2/one_key_wp_v2.py:600: SyntaxWarning: invalid escape sequence '\s'
result = re.search('Download\s+WordPress\s+([\d.]+)', result.text)
/www/server/panel/class_v2/one_key_wp_v2.py:858: SyntaxWarning: invalid escape sequence '\d'
if re.search('\d+', args.d_id):
/www/server/panel/class_v2/one_key_wp_v2.py:863: SyntaxWarning: invalid escape sequence '\d'
if re.search('\d+', args.s_id):
/www/server/panel/class_v2/one_key_wp_v2.py:1300: SyntaxWarning: invalid escape sequence '.'
conf = """
/www/server/panel/class_v2/one_key_wp_v2.py:1376: SyntaxWarning: invalid escape sequence '\s'
rep = "http\s\n\s{"
/www/server/panel/class_v2/one_key_wp_v2.py:1410: SyntaxWarning: invalid escape sequence '\$'
rep2 = "\$NGINX_BIN -c \$CONFIGFILE"
/www/server/panel/class_v2/one_key_wp_v2.py:1448: SyntaxWarning: invalid escape sequence '\s'
rep = "include\s+enable-php-{}-wpfastcgi.conf;".format(version)
/www/server/panel/class_v2/one_key_wp_v2.py:1457: SyntaxWarning: invalid escape sequence '\s'
rep = "include\s+enable-php-{}.conf;".format(version)
/www/server/panel/BT-Panel:63: SyntaxWarning: invalid escape sequence '\c'
os.system("\cp -f {} {}".format(plugin_loader_src_file, plugin_loader_file))
/www/server/panel/BT-Panel:238: DeprecationWarning: setDaemon() is deprecated, set the daemon attribute instead
task_thread.setDaemon(True)
[2024-05-19 20:43:46][DEBUG] - sub_path:
[2024-05-19 20:44:12][DEBUG] - sub_path:
[2024-05-19 20:45:25][DEBUG] - sub_path:
[2024-05-19 20:49:09][DEBUG] - sub_path:
[2024-05-19 20:51:19][DEBUG] - sub_path:
[2024-05-19 20:51:46][DEBUG] - sub_path: `
