ovsas aaPanel_Kern how? upd: I added database through phpmyadmin with latin1_swedish_ci collation, but how to change charset?
aaPanel_Kern It is recommended that you back up the database and then re-establish the database. ovsas
ovsas aaPanel_Kern now Server charset: UTF-8 Unicode (utf8mb4), what i have to do to change that? how re-estable charset to be latin1? can you write me commands?
aaPanel_Kern The character set of the system is different from that of the database. Generally, you only need to deal with the character set of the database. ovsas
aaPanel_Kern After backing up the database, delete the database in the panel, add the database in phpmyadmin and specify the character set
ovsas aaPanel_Kern when i add database through phpmyadmin, i can set only collation, but not charset. how to chose charset?
aaPanel_Kern Hello, I suggest you check if the latin1 character set using the word Atvečiaju and the letter č is correct Or you can try the utf8mb4_unicode_ci character set ovsas
