aaP_dev_zerone1 Saya perlu bantuan untuk mengatasi cpu server saya 100% load. Saya menggunakan NGINX dan database mysql
aaPanel_Kern Hello, it is recommended that you check the slow log or use phpmyadmin to check the mysql process. aaP_dev_zerone1
aaPanel_Kern Hello, if the query is too slow, it will cause mysql to occupy a high CPU. It is recommended that you check the specific sql statement.
