aaPanel_Kern Hello, what error message does the installation prompt? Please check the installation log: /tmp/panelExec.log mohamed76
mohamed76 aaPanel_Kern System😃ebian GNU/Linux 11 x86_64(Py3.7.9) no its same , i try to update Debian , but its no change
aaPanel_Kern Hello, you should have installed apache 2.2? If so, it is recommended that you use version 2.4 or use nginx mohamed76
