Hi,
The server shows the webs without problem but I can't access the panel.
systemctl status bt
Warning: The unit file, source configuration file or drop-ins of bt.service changed on disk. Run 'system>
● bt.service - LSB: starts bt
Loaded: loaded (/etc/init.d/bt; generated)
Active: failed (Result: oom-kill) since Tue 2024-XX-XX XX:XX:XX CEST; XXh ago
Docs: man:systemd-sysv-generator(8)
Process: 802 ExecStart=/etc/init.d/bt start (code=exited, status=0/SUCCESS)
Process: 631108 ExecStop=/etc/init.d/bt stop (code=exited, status=0/SUCCESS)
Tasks: 236 (limit: 4535)
Memory: 1.8G
CPU: 12h 24min 23.150s
CGroup: /system.slice/bt.service
├─ 85494 /www/server/apache/bin/httpd -k graceful
├─437154 php-fpm: master process (/www/server/php/82/etc/php-fpm.conf)
├─437155 php-fpm: pool www
├─437156 php-fpm: pool www
├─437157 php-fpm: pool www
├─437159 php-fpm: pool www
├─437168 php-fpm: pool www
├─437204 php-fpm: pool www
├─437227 php-fpm: pool www
├─441319 php-fpm: pool www
├─444532 php-fpm: pool www
├─448258 php-fpm: pool www
├─455763 php-fpm: pool www
├─502248 php-fpm: pool www
├─532902 php-fpm: pool www
├─543804 php-fpm: pool www
├─629827 php-fpm: pool www
├─631093 php-fpm: pool www
├─631095 php-fpm: pool www
├─631096 php-fpm: pool www
├─631099 php-fpm: pool www
├─631100 php-fpm: pool www
├─631101 php-fpm: pool www
├─631102 php-fpm: pool www
├─631137 php-fpm: pool www
├─631167 php-fpm: pool www
├─631363 php-fpm: pool www
├─631386 php-fpm: pool www
├─634346 /www/server/apache/bin/httpd -k graceful
├─634347 /www/server/apache/bin/httpd -k graceful
├─634350 /www/server/apache/bin/httpd -k graceful
└─634512 /www/server/apache/bin/httpd -k graceful
systemctl start|restart bt
Warning: The unit file, source configuration file or drop-ins of bt.service changed on disk. Run 'systemctl daemon-reload' to reload units.
systemctl daemon-reload and systemctl restart bt
The panel starts and allows me to log in. Any idea how to fix and avoid errors like this?
Is it possible that it is related to the SSL renewal of the panel's subdomain?
Thanks!
