My panel keeps loading. but the website works normally, only the panel can't respond if I click on the menu, I checked the error via SSH and it appeared like this...
uests/sessions.py", line 529, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/req
uests/sessions.py", line 645, in send
uests/adapters.py", line 519, in send
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='
www.bt.cn', port=443): Max retries exceeded with url: /api/ip/i
nfo (Caused by NewConnectionError('<urllib3.connection.HTTPSCon
nection object at 0x7fa2b2d6f0d0>: Failed to establish a new co
nnection: [Errno 101] Network is unreachable'))
['5', '15', '0', '94']
[2024-04-30 04:02:23][DEBUG] - Traceback (most recent call last
File "/www/server/panel/pyenv/lib/python3.7/site-packages/url
lib3/connection.py", line 175, in new_conn
lib3/util/connection.py", line 95, in create_connection
raise err
lib3/util/connection.py", line 85, in create_connection
sock.connect(sa)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gev
ent/_socketcommon.py", line 628, in connect
raise _SocketError(result, strerror(result))
OSError: [Errno 101] Network is unreachable
During handling of the above exception, another exception occur
red:
lib3/connectionpool.py", line 722, in urlopen
chunked=chunked,
lib3/connectionpool.py", line 404, in make_request
self.validate_conn(conn)
lib3/connectionpool.py", line 1058, in validate_conn
conn.connect()
lib3/connection.py", line 363, in connect
self.sock = conn = self.new_conn()
lib3/connection.py", line 187, in _new_conn
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTP
SConnection object at 0x7fa2b009f2d0>: Failed to establish a ne
w connection: [Errno 101] Network is unreachable
red:
uests/adapters.py", line 450, in send
timeout=timeout
lib3/connectionpool.py", line 800, in urlopen
method, url, error=e, _pool=self, stacktrace=sys.exc_info(
)[2]
lib3/util/retry.py", line 592, in increment
raise MaxRetryError(pool, url, error or ResponseError(caus
e))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='bra
ndnew.aapanel.com', port=443): Max retries exceeded with url: /
api/panel/updateLinuxEn (Caused by NewConnectionError('<urllib3
.connection.HTTPSConnection object at 0x7fa2b009f2d0>: Failed t
o establish a new connection: [Errno 101] Network is unreachabl
e'))
red:
File "class/http_requests.py", line 103, in post
result = requests.post(url,data,timeout=timeout,headers=hea
ders,verify=verify)
uests/api.py", line 117, in post
uests/api.py", line 61, in request
brandnew.aapanel.com', port=443): Max retries exceeded with url
: /api/panel/updateLinuxEn (Caused by NewConnectionError('<urll
ib3.connection.HTTPSConnection object at 0x7fa2b009f2d0>: Faile
d to establish a new connection: [Errno 101] Network is unreach
able'))
