aaPanel_Kern adhitya Hi, will trying this command fix it? wget --no-check-certificate -O /etc/init.d/bt https://node.aapanel.com/install/src/bt6_en.init -T 20 chmod +x /etc/init.d/bt && bt
adhitya aaPanel_Kern the web panel page cannot be accessed. Meanwhile, the existing website can run well, but the Aapanel cannot be accessed
aaPanel_Kern adhitya Hello, please check if bt service is running: bt status If it doesn't start, try starting it manually:bt start
aaPanel_Kern Hello, does the website use CDN or the like? Also check whether the permissions of the website directory are 755/www? adhitya
