ezonlinetools I'm currently using aaPanel version 6.8.36 on Ubuntu 20.04 64 Bit. I want to change the default port that nginx listens on from 80 to another port. Please assist me how to change nginx port?
aaPanel_Kern Hello, you can modify the /www/server/panel/vhost/nginx/ configuration file ezonlinetools
aaPanel_Kern All related ports need to be modified, but it is not recommended that you modify it. If you add a website after modification, if you do not specify a port, port 80 will be used by default. ezonlinetools
ezonlinetools please check this image. i'm trying to install discourse & it's showing me this error message. Port 80 appears to already be in use. that's why i ask how to change this port.
ezonlinetools how it is possible? can you please assist me how to modify discourse to use other ports? thanks in advance.
