Thank you Kern, I have put the path and it takes it, now I try to check again how is going and I might get back to the forum with my last resolution. Ty
Here is a video of working roundcube with smtp relay OFF, and after smtp Relay ON my email not send to the gmail inbox.
What do you Think Kern, have you encounter those kind things, what I should do to fix this to make my smtp relay work on aApanel, any help will be great.
Video: https://vimeo.com/938043334?share=copy
    Also my server send to gmail to inbox but on yahoo not receive anything
    I need to use port 25 by default for SMTP RELAY or SMTP, where I can change to have 25 the port for my internal email servers and to use 587 for the secured external email traffic?
    SuperTool Beta7
    alinaroman.ro
    mx:alinaroman.ro
    Gmail & Yahoo are now requiring DMARC - Get your's setup with Delivery Center
    Pref Hostname IP Address TTL
    10 mail.alinaroman.ro 62.169.30.22
    Unknown (AS51167) 24 hrs Blacklist Check SMTP Test
    Test Result
    Status Ok DMARC Record Published DMARC Record found
    Status Ok DMARC Policy Not Enabled DMARC Quarantine/Reject policy enabled
    Status Ok DNS Record Published DNS Record found
    220 vmi1812900.contaboserver.net ESMTP Postfix (Ubuntu)
    Test Result
    Status Ok SMTP Reverse DNS Mismatch OK - 62.169.30.22 resolves to vmi1812900.contaboserver.net
    Status Ok SMTP Valid Hostname OK - Reverse DNS is a valid Hostname
    Status Ok SMTP Banner Check OK - Reverse DNS matches SMTP Banner
    Status Ok SMTP TLS OK - Supports TLS.
    Status Ok SMTP Connection Time 0.349 seconds - Good on Connection time
    Status Ok SMTP Open Relay OK - Not an open relay.
    Status Ok SMTP Transaction Time 1.108 seconds - Good on Transaction Time
    Session Transcript:
    Connecting to 62.169.30.22
    220 vmi1812900.contaboserver.net ESMTP Postfix (Ubuntu) [204 ms]
    EHLO keeper-us-east-1d.mxtoolbox.com
    250-vmi1812900.contaboserver.net
    250-PIPELINING
    250-SIZE 102400000
    250-VRFY
    250-ETRN
    250-STARTTLS
    250-AUTH PLAIN LOGIN
    250-ENHANCEDSTATUSCODES
    250-8BITMIME
    250-DSN
    250-SMTPUTF8
    250 CHUNKING [217 ms]
    MAIL FROM:supertool@mxtoolboxsmtpdiag.com
    250 2.1.0 Ok [216 ms]
    RCPT TO:test@mxtoolboxsmtpdiag.com
    554 5.7.1 test@mxtoolboxsmtpdiag.com: Relay access denied [226 ms]
    LookupServer 1788ms
    I'm stucked with this contabo DNS setup, I not know where is the error and why SMTP RELAY when is open not work
    aaPanel_Kern Hey Kern, My config file is the default one, i put config file here, now I have the smtp relay off because i try to put the ssl of main domain to the webmail domain and not get forced by SSL, here it goes the config file, take a look, default one: # See /usr/share/postfix/main.cf.dist for a commented, more complete version
    Debian specific: Specifying a file name will cause the first
    line of that file to be used as the name. The Debian default
    is /etc/mailname.
    #myorigin = /etc/mailname
    smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
    biff = no
    appending .domain is the MUA's job.
    append_dot_mydomain = no
    Uncomment the next line to generate "delayed mail" warnings
    #delay_warning_time = 4h
    readme_directory = no
    See http://www.postfix.org/COMPATIBILITY_README.html -- default to 2 on
    fresh installs.
    compatibility_level = 2
    TLS parameters
    #smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
    #smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
    smtpd_tls_security_level = may
    smtp_tls_CApath=/etc/ssl/certs
    smtp_tls_security_level = may
    smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
    smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_unauth_destination
    myhostname = vmi1812900.contaboserver.net
    alias_maps = hash:/etc/aliases
    alias_database = hash:/etc/aliases
    mydestination =
    relayhost =
    mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
    mailbox_command = procmail -a "$EXTENSION"
    mailbox_size_limit = 0
    recipient_delimiter = +
    inet_interfaces = all
    inet_protocols = all
    virtual_mailbox_domains = sqlite:/etc/postfix/sqlite_virtual_domains_maps.cf
    virtual_alias_maps = sqlite:/etc/postfix/sqlite_virtual_alias_maps.cf, sqlite:/etc/postfix/sqlite_virtual_alias_domain_maps.cf, sqlite:/etc/postfix/sqlite_virtual_alias_domain_catchall_maps.cf
    virtual_mailbox_maps = sqlite:/etc/postfix/sqlite_virtual_mailbox_maps.cf, sqlite:/etc/postfix/sqlite_virtual_alias_domain_mailbox_maps.cf
    smtpd_sasl_type = dovecot
    smtpd_sasl_path = private/auth
    smtpd_sasl_auth_enable = yes
    smtpd_recipient_restrictions = permit_sasl_authenticated, permit_mynetworks, reject_unauth_destination
    smtpd_use_tls = yes
    virtual_transport = lmtp:unix:private/dovecot-lmtp
    smtpd_milters = inet:127.0.0.1:11332
    non_smtpd_milters = inet:127.0.0.1:11332
    milter_mail_macros = i {mail_addr} {client_addr} {client_name} {auth_authen}
    milter_protocol = 6
    milter_default_action = accept
    message_size_limit = 102400000
    smtpd_tls_chain_files = /www/server/panel/plugin/mail_sys/cert/alinaroman.ro/fullchain.pem
    tls_server_sni_maps = hash:/etc/postfix/vmail_ssl.map
      Ok, I have put the SSL from main domain to the mail section domain how is it in tutorial, because i was forget to put that in the start, now I just only need to check if the smtp relay work, and if it will send to inbox in yahoo mail.
      Do you think is better for me to use cloudflare than contabo dns manager? Because my emails are not going at all in yahoo mail but in google it works like a charm
      I tested Outlook on my roundcube = OK, works
      I tested Yahoo on my roundcube = Not work at all host mta5.am0.yahoodns.net[67.195.228.111] said: 553
      5.7.2 [TSS09] All messages from 62.169.30.22 will be permanently deferred;
      I tested Google on my roundcube = Works on Inbox
      All tests was taken with sending and receiving emails from aapanel mail.
      Hi Kern, I was managed to make it WORK, I installed fluent SMTP (free plugin) to wordpress, I have put aapanel details for user login into fluent SMTP, and the test mail was going to the GMAIL inbox, now I try to make all the settings for my email to go good in Yahoo-Mail, because my mails are not send at all, if you have some tips regarding this Yahoo mail issue will be good, if not I will try to fix myself from internet resources.
      Best, HAIL AAPANEL!
