touseef https://xxx.com:7800/xx im trying to access my filemanager of Aapanel but why its not accessible before it was working fine
aaPanel_Kern touseef Hello, what information does it prompt that you cannot access? Are other interfaces normal?
touseef Your connection is not private Attackers might be trying to steal your information from aiglamorous.com (for example, passwords, messages or credit cards). Learn more NET::ERR_CERT_DATE_INVALID
aaPanel_Kern Hello, it is recommended that you cancel the domain name binding. You can use the command bt 12 Then use the server's IP to access. This is because your website certificate is inconsistent with the certificate used by the panel and the browser does not allow access. touseef
