webwilliam Hello! I recently hired a VPS from Contabo with 300 GB of storage. However, after installing AApanel, I noticed that it only recognizes 95.9 GB. I don't have enough technical knowledge to resolve this issue. Could you help me? I t's a new server.
aaPanel_Kern webwilliam Hello, this is caused by not adding space to the system. It is recommended that you contact the server provider for assistance.
Nanno If you are running Linux at the VPS, then you can open the Terminal (available in the aaPanel) and check the total disk space the VPS has with the command df -h / If it shows 95 GB of space, then you have to contact Contabo support.
webwilliam Thank you very much for the support. The image below shows a screenshot taken after using the mentioned command (df -h /) in the terminal.
