aaP_quochung1998_cit Hello, I want to block access to a site for requests with invalid values in the “Referer” header field. How to apply this on aaPanel ?
aaPanel_Kern Hello, this is a built-in module and does not need to be installed. Please add the relevant configuration directly to the site configuration. aaP_quochung1998_cit
aaP_quochung1998_cit aaPanel_Kern How can I install one of the other modules? https://github.com/nginx/nginx
aaPanel_Kern Hello, I suggest you specify which modules you want to install. The nginx -V command can view installed modules, but built-in modules will not be listed. aaP_quochung1998_cit
aaPanel_Kern aaP_quochung1998_cit Hello, try to refer to this tutorial https://www.aapanel.com/forum/d/1015-how-to-compile-and-install-third-party-modules-in-aapanel-nginx
