akkilah I have issue now which is when I login to ip address all icons are not there and SSL certificate are not activated in ip address only [https://prnt.sc/DgCAtjh9f6fH](https://)
aaPanel_Kern Hello, press F12 on the browser and then go to the network interface to check if there are any errors? akkilah
akkilah aaPanel_Kern can you tell me how to fix ssl it is more important than icon i think icon will be fixed after ssl installed correctly
akkilah this what came out https://prnt.sc/3WLtrn2SzSe8 you can check also from your browser if can please it would be helpful from you
aaPanel_Kern akkilah Hello, it is prompted that there is a CORS cross-domain error. It is recommended that you check what link you are accessing. You can check these two in the upper right corner for troubleshooting.
