aaPanel_Kern Hello, it says that the container is not running. It is recommended that you use btw 18 to check what is the reason mohamed-hamed
aaPanel_Kern mohamed-hamed aawaf needs to use port 80 443. It is recommended that you use a new server to install it.
aaPanel_Kern Please make sure that the new server does not use port 80 443 before installing aawaf mohamed-hamed
aaPanel_Kern aawaf needs to use port 80 443. It is recommended that you use a new server to install it. The web service of aapanel can no longer be installed.
