aaPanel_Jose lnhax Because several users have experienced website exceptions when the traffic is high, we decided to increase the [ LSAPI_CHILDREN ] parameter from the default 10 to 20 in the website configuration.
jazz1611 @aaPanel_Jose hello, when you can add feature "custom port default of webserver"? new bug with backup log [All]
aaPanel_Jose gorkinyon please try to install this package pip install bcrypt pip install cryptography pip install pycryptodome bt reload
NinjutsuDEV @aaPanel_Jose Why is the wait time in "WebSite Accelerator" still so long? I have to wait about 1 to 2 minutes between each action before I can do another action. An example, enable or disable the module, change the cache size or simply start the "Wizard". Even adding rules is too slow waiting for it to stop saying "Processing request, please wait..."
NinjutsuDEV In the case of a wordpress site, I am removing a rule that excludes caching of JS files and I have been waiting for 4 minutes for it to stop saying "Processing request, please wait ..."
aaPanel_Jose NinjutsuDEV Thanks for your feedback, let me check jazz1611 This is because port 8080 will be used in the java project manager of the panel, so it limits the user to add you can delete it in /www/server/panel/class/public.py
