• Support
  • An error occurred while the panel was running!
Hello
I get the following error when I log into my panel
Even restarting the panel and doing FIX, but the problem was not solved
File "/www/server/panel/BTPanel/__init__.py", line 1950, in publicObject
File "/www/server/panel/BTPanel/__init__.py", line 1902, in run
File "class/panelPlugin.py", line 758, in get_index_list
softList = self.get_cloud_list(get)['list']
File "class/panelPlugin.py", line 420, in get_cloud_list
softList['list'] = self.get_local_plugin(softList['list'])
TypeError: string indices must be integers
Please help me how to solve the problem
    Hello, the problem was with the country's internet infrastructure, and there was no access to the panel with a blocked external IP, now my problem has been solved
      5 months later
      This error occurs when you enter the login page in the Bind account section of the aa panel.
      The error has been resolved by the team you mentioned above with your support.
        Post link:
        Detailed problem description:
        JADEFEWr39285390t
        a month later
        why this aa panel is giving us tuff time, I noted this issue for me a second time, it was re install fully now again I am facing issue after 3 more month. I can get login successfully then I am getting this error, any body can help me to solve this issue,
        Regards
          Hello, is it possible to try to update app list by clicking on the upper right corner of the app store?
          aaP_info396
