aaP_ilhampradana219 after I changed the Worker connections 51200 to 1024 now nginx can't even start even though I returned it to 51200.
aaPanel_Kern aaP_ilhampradana219 Hello, is the problem solved? Check the Error logs. What is the relevant information? You can also use this command to check if there is any problem with the configuration file? /www/server/nginx/sbin/nginx -t
