I would like to know which operating system to install to have stability for at least 2 years, I was using CentOS Stream 8, but its support ends in 2 months. I tried to install a new server with CentOS Stream 9, but I can't install mariadb and it gives other errors. So I think it is not compatible with the current version of aapanel. I also tried with Debian 12 and it gives errors installing some packages. What do you suggest me to use as a system that has support and is compatible with aapanel? Thanks
