oneglash I think there is an issues with AApanel V6.8.36 when installing Roundcube, the AAPanel not creating database for Roundcube and the result Roundcube not opening and not working Please check with developers once
aaPanel_Kern Hello, it is recommended to create a new test11 database in the Databases interface to check whether it is normal? oneglash
oneglash well it is not working i guess coz not allowing to create Database also , i have old version of AApanel as well and that works fine but with the new installation and new version having issues , please check that ,
aaPanel_Kern It is recommended that mysql is running normally? Check whether the root user password of mysql is correct oneglash
aaPanel_Kern Hello, try to change the root password in the database interface and then create the database. Is it normal? oneglash
