Dscj Hi, I am unable to install PHP Extensions,tried uninstalling PHP 8.2,8.3,it shows uninstalling but doesnt uninstall.I have tried restart panel/server as well. Tried to remove php from terminal too. Anyone please suggest urgent resolution, Thanks
aaPanel_Kern Hello, is there any error message? Is it possible to uninstall if you try using the command? uninstall php 8.3: bash /www/server/panel/install/php.sh uninstall 8.3
Dscj Php has been uninstalled,now when i try to install php 8.3 or extensions i get only this screen loading..nothing else. I have already tried restarting panel/server.Please suggest.
Dscj already did twice/thrice.same issue persists.Any command to do same in terminal or any other solution?
aaPanel_Kern Hi, can you give us your aapanel information? The server makes a snapshot backup first, if possible, please send it to kern@aapanel.com. It is recommended to fill in the following Post link: SSH IP address, account password and port: aapanel login link address and account password: No post link will not be able to know which user's information is, and the problem will not be processed Dscj
