aaPanel_Kern We need a simple solution for:
- Switch from MariaDB to MySQL or reverse
- Change MySQL / MariaDB version with only one click
Unlike DirectAdmin when i want to switch from MariaDB to MySQL, i have to take backup from all databases, uninstall MariaDB, then i have to install MySQL and import all databases.
The problem is that this process takes a lot and causes long outages in website, also due to the non-automation of the process, there are many risks to the databases.
In DirectAdmin i press a single button and everything handles automatically.
It would be great if you add a fast solution to replace Apache/Nginx with lowest downtime.
