There is other error:
`LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Installing MySQL system tables...2024-03-22 08:29:48 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2024-03-22 08:29:48 0 [Note] Ignoring --secure-file-priv value as server is running with --bootstrap.
2024-03-22 08:29:48 0 [Note] /www/server/mysql/bin/mysqld (mysqld 5.6.50-log) starting as process 702279 ...
2024-03-22 08:29:48 702279 [Note] InnoDB: Using atomics to ref count buffer pool pages
2024-03-22 08:29:48 702279 [Note] InnoDB: The InnoDB memory heap is disabled
2024-03-22 08:29:48 702279 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2024-03-22 08:29:48 702279 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2024-03-22 08:29:48 702279 [Note] InnoDB: Compressed tables use zlib 1.2.11
2024-03-22 08:29:48 702279 [Note] InnoDB: Using Linux native AIO
2024-03-22 08:29:48 702279 [Note] InnoDB: Not using CPU crc32 instructions
2024-03-22 08:29:48 702279 [Note] InnoDB: Initializing buffer pool, size = 2.0G
2024-03-22 08:29:48 702279 [Note] InnoDB: Completed initialization of buffer pool
2024-03-22 08:29:48 702279 [Note] InnoDB: The first specified data file /www/server/data/ibdata1 did not exist: a new database to be created!
2024-03-22 08:29:48 702279 [Note] InnoDB: Setting file /www/server/data/ibdata1 size to 10 MB
2024-03-22 08:29:48 702279 [Note] InnoDB: Database physically writes the file full: wait...
2024-03-22 08:29:48 702279 [Note] InnoDB: Setting log file /www/server/data/ib_logfile101 size to 1024 MB
InnoDB: Progress in MB: 100 200 300 400 500 600 700 800 900 1000
2024-03-22 08:29:52 702279 [Note] InnoDB: Setting log file /www/server/data/ib_logfile1 size to 1024 MB
2024-03-22 08:29:56 702279 [Note] InnoDB: Renaming log file /www/server/data/ib_logfile101 to /www/server/data/ib_logfile0
2024-03-22 08:29:56 702279 [Warning] InnoDB: New log files created, LSN=45781
2024-03-22 08:29:56 702279 [Note] InnoDB: Doublewrite buffer not found: creating new
2024-03-22 08:29:57 702279 [Note] InnoDB: Doublewrite buffer created
2024-03-22 08:29:57 702279 [Note] InnoDB: 128 rollback segment(s) are active.
2024-03-22 08:29:57 702279 [Warning] InnoDB: Creating foreign key constraint system tables.
2024-03-22 08:29:57 702279 [Note] InnoDB: Foreign key constraint system tables created
2024-03-22 08:29:57 702279 [Note] InnoDB: Creating tablespace and datafile system tables.
2024-03-22 08:29:57 702279 [Note] InnoDB: Tablespace and datafile system tables created.
2024-03-22 08:29:57 702279 [Note] InnoDB: Waiting for purge to start
2024-03-22 08:29:57 702279 [Note] InnoDB: 5.6.50 started; log sequence number 0
2024-03-22 08:29:57 702279 [Note] RSA private key file not found: /www/server/data//private_key.pem. Some authentication plugins will not work.
2024-03-22 08:29:57 702279 [Note] RSA public key file not found: /www/server/data//public_key.pem. Some authentication plugins will not work.
2024-03-22 08:29:58 702279 [Note] Binlog end
2024-03-22 08:29:58 702279 [Note] InnoDB: FTS optimize thread exiting.
2024-03-22 08:29:58 702279 [Note] InnoDB: Starting shutdown...
2024-03-22 08:30:00 702279 [Note] InnoDB: Shutdown completed; log sequence number 1625984
OK
Filling help tables...2024-03-22 08:30:00 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2024-03-22 08:30:00 0 [Note] Ignoring --secure-file-priv value as server is running with --bootstrap.
2024-03-22 08:30:00 0 [Note] /www/server/mysql/bin/mysqld (mysqld 5.6.50-log) starting as process 702330 ...
2024-03-22 08:30:00 702330 [Note] InnoDB: Using atomics to ref count buffer pool pages
2024-03-22 08:30:00 702330 [Note] InnoDB: The InnoDB memory heap is disabled
2024-03-22 08:30:00 702330 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2024-03-22 08:30:00 702330 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2024-03-22 08:30:00 702330 [Note] InnoDB: Compressed tables use zlib 1.2.11
2024-03-22 08:30:00 702330 [Note] InnoDB: Using Linux native AIO
2024-03-22 08:30:00 702330 [Note] InnoDB: Not using CPU crc32 instructions
2024-03-22 08:30:00 702330 [Note] InnoDB: Initializing buffer pool, size = 2.0G
2024-03-22 08:30:00 702330 [Note] InnoDB: Completed initialization of buffer pool
2024-03-22 08:30:00 702330 [Note] InnoDB: Highest supported file format is Barracuda.
2024-03-22 08:30:00 702330 [Note] InnoDB: 128 rollback segment(s) are active.
2024-03-22 08:30:00 702330 [Note] InnoDB: Waiting for purge to start
2024-03-22 08:30:00 702330 [Note] InnoDB: 5.6.50 started; log sequence number 1625984
2024-03-22 08:30:00 702330 [Note] RSA private key file not found: /www/server/data//private_key.pem. Some authentication plugins will not work.
2024-03-22 08:30:00 702330 [Note] RSA public key file not found: /www/server/data//public_key.pem. Some authentication plugins will not work.
2024-03-22 08:30:00 702330 [Note] Binlog end
2024-03-22 08:30:00 702330 [Note] InnoDB: FTS optimize thread exiting.
2024-03-22 08:30:00 702330 [Note] InnoDB: Starting shutdown...
2024-03-22 08:30:02 702330 [Note] InnoDB: Shutdown completed; log sequence number 1625994
OK
To start mysqld at boot time you have to copy
support-files/mysql.server to the right place for your system
PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
To do so, start the server, then issue the following commands:
/www/server/mysql/bin/mysqladmin -u root password 'new-password'
/www/server/mysql/bin/mysqladmin -u root -h 5a949ab6c2a6 password 'new-password'
Alternatively you can run:
/www/server/mysql/bin/mysql_secure_installation
which will also give you the option of removing the test
databases and anonymous user created by default. This is
strongly recommended for production servers.
See the manual for more instructions.
You can start the MySQL daemon with:
cd . ; /www/server/mysql/bin/mysqld_safe &
You can test the MySQL daemon with mysql-test-run.pl
cd mysql-test ; perl mysql-test-run.pl
Please report any problems at http://bugs.mysql.com/
The latest information about MySQL is available on the web at
http://www.mysql.com
Support MySQL by buying support/licenses at http://shop.mysql.com
New default config file was created as /www/server/mysql/my.cnf and
will be used by default by the server when you start it.
You may edit this file to change server settings
WARNING: Default config file /etc/my.cnf exists on the system
This file will be read by default by the MySQL server
If you do not want to use this, either remove it, or use the
--defaults-file argument to mysqld_safe when starting the server
Starting MySQL.Logging to '/www/server/data/5a949ab6c2a6.err'.
.. ERROR! The server quit without updating PID file (/www/server/data/5a949ab6c2a6.pid).
/www/server/mysql/bin/mysqladmin: connect to server at 'localhost' failed
error: 'Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)'
Check that mysqld is running and that the socket: '/tmp/mysql.sock' exists!
Starting MySQL... ERROR! The server quit without updating PID file (/www/server/data/5a949ab6c2a6.pid).
WARNING: Skipping MySQL-python as it is not installed.
WARNING: Skipping mysqlclient as it is not installed.
Found existing installation: PyMySQL 0.9.3
Uninstalling PyMySQL-0.9.3:
Successfully uninstalled PyMySQL-0.9.3
--2024-03-22 08:30:10-- https://na1-node.bt.cn/install/src/PyMySQL-0.9.3.zip
Resolving na1-node.bt.cn (na1-node.bt.cn)... 128.1.164.196
Connecting to na1-node.bt.cn (na1-node.bt.cn)|128.1.164.196|:443... connected.
Length: 108696 (106K) [application/zip]
Saving to: 'src.zip'
writing requirements to PyMySQL.egg-info/requires.txt
writing top-level names to PyMySQL.egg-info/top_level.txt
writing manifest file 'PyMySQL.egg-info/SOURCES.txt'
reading manifest file 'PyMySQL.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
installing library code to build/bdist.linux-aarch64/egg
running install_lib
running build_py
creating build
creating build/lib
creating build/lib/pymysql
copying pymysql/charset.py -> build/lib/pymysql
copying pymysql/init.py -> build/lib/pymysql
copying pymysql/converters.py -> build/lib/pymysql
copying pymysql/optionfile.py -> build/lib/pymysql
copying pymysql/socketio.py -> build/lib/pymysql
copying pymysql/auth.py -> build/lib/pymysql
copying pymysql/connections.py -> build/lib/pymysql
copying pymysql/protocol.py -> build/lib/pymysql
copying pymysql/util.py -> build/lib/pymysql
copying pymysql/times.py -> build/lib/pymysql
copying pymysql/compat.py -> build/lib/pymysql
copying pymysql/err.py -> build/lib/pymysql
copying pymysql/cursors.py -> build/lib/pymysql
creating build/lib/pymysql/constants
copying pymysql/constants/init.py -> build/lib/pymysql/constants
copying pymysql/constants/CLIENT.py -> build/lib/pymysql/constants
copying pymysql/constants/FIELD_TYPE.py -> build/lib/pymysql/constants
copying pymysql/constants/COMMAND.py -> build/lib/pymysql/constants
copying pymysql/constants/CR.py -> build/lib/pymysql/constants
copying pymysql/constants/FLAG.py -> build/lib/pymysql/constants
copying pymysql/constants/ER.py -> build/lib/pymysql/constants
copying pymysql/constants/SERVER_STATUS.py -> build/lib/pymysql/constants
creating build/bdist.linux-aarch64
creating build/bdist.linux-aarch64/egg
creating build/bdist.linux-aarch64/egg/pymysql
copying build/lib/pymysql/charset.py -> build/bdist.linux-aarch64/egg/pymysql
copying build/lib/pymysql/init.py -> build/bdist.linux-aarch64/egg/pymysql
copying build/lib/pymysql/converters.py -> build/bdist.linux-aarch64/egg/pymysql
copying build/lib/pymysql/optionfile.py -> build/bdist.linux-aarch64/egg/pymysql
copying build/lib/pymysql/socketio.py -> build/bdist.linux-aarch64/egg/pymysql
copying build/lib/pymysql/auth.py -> build/bdist.linux-aarch64/egg/pymysql
copying build/lib/pymysql/connections.py -> build/bdist.linux-aarch64/egg/pymysql
copying build/lib/pymysql/protocol.py -> build/bdist.linux-aarch64/egg/pymysql
creating build/bdist.linux-aarch64/egg/pymysql/constants
copying build/lib/pymysql/constants/init.py -> build/bdist.linux-aarch64/egg/pymysql/constants
copying build/lib/pymysql/constants/CLIENT.py -> build/bdist.linux-aarch64/egg/pymysql/constants
copying build/lib/pymysql/constants/FIELD_TYPE.py -> build/bdist.linux-aarch64/egg/pymysql/constants
copying build/lib/pymysql/constants/COMMAND.py -> build/bdist.linux-aarch64/egg/pymysql/constants
copying build/lib/pymysql/constants/CR.py -> build/bdist.linux-aarch64/egg/pymysql/constants
copying build/lib/pymysql/constants/FLAG.py -> build/bdist.linux-aarch64/egg/pymysql/constants
copying build/lib/pymysql/constants/ER.py -> build/bdist.linux-aarch64/egg/pymysql/constants
copying build/lib/pymysql/constants/SERVER_STATUS.py -> build/bdist.linux-aarch64/egg/pymysql/constants
copying build/lib/pymysql/util.py -> build/bdist.linux-aarch64/egg/pymysql
copying build/lib/pymysql/times.py -> build/bdist.linux-aarch64/egg/pymysql
copying build/lib/pymysql/compat.py -> build/bdist.linux-aarch64/egg/pymysql
copying build/lib/pymysql/err.py -> build/bdist.linux-aarch64/egg/pymysql
copying build/lib/pymysql/cursors.py -> build/bdist.linux-aarch64/egg/pymysql
byte-compiling build/bdist.linux-aarch64/egg/pymysql/charset.py to charset.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/init.py to init.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/converters.py to converters.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/optionfile.py to optionfile.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/_socketio.py to socketio.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/auth.py to auth.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/connections.py to connections.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/protocol.py to protocol.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/constants/init.py to init.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/constants/CLIENT.py to CLIENT.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/constants/FIELD_TYPE.py to FIELD_TYPE.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/constants/COMMAND.py to COMMAND.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/constants/CR.py to CR.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/constants/FLAG.py to FLAG.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/constants/ER.py to ER.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/constants/SERVER_STATUS.py to SERVER_STATUS.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/util.py to util.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/times.py to times.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/compat.py to _compat.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/err.py to err.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/pymysql/cursors.py to cursors.cpython-37.pyc
creating build/bdist.linux-aarch64/egg/EGG-INFO
copying PyMySQL.egg-info/PKG-INFO -> build/bdist.linux-aarch64/egg/EGG-INFO
copying PyMySQL.egg-info/SOURCES.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying PyMySQL.egg-info/dependency_links.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying PyMySQL.egg-info/requires.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying PyMySQL.egg-info/top_level.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
zip_safe flag not set; analyzing archive contents...
creating dist
creating 'dist/PyMySQL-0.9.3-py3.7.egg' and adding 'build/bdist.linux-aarch64/egg' to it
removing 'build/bdist.linux-aarch64/egg' (and everything under it)
Processing PyMySQL-0.9.3-py3.7.egg
Copying PyMySQL-0.9.3-py3.7.egg to /www/server/panel/pyenv/lib/python3.7/site-packages
Adding PyMySQL 0.9.3 to easy-install.pth file
Installed /www/server/panel/pyenv/lib/python3.7/site-packages/PyMySQL-0.9.3-py3.7.egg
Processing dependencies for PyMySQL==0.9.3
Finished processing dependencies for PyMySQL==0.9.3
Reload Bt-Panel.. [32mdone[0m
ERROR! MySQL server PID file could not be found!
Changing password...
240322 08:30:14 mysqld_safe Logging to '/www/server/data/5a949ab6c2a6.err'.
240322 08:30:14 mysqld_safe Starting mysqld daemon with databases from /www/server/data
240322 08:30:16 mysqld_safe mysqld from pid file /www/server/data/5a949ab6c2a6.pid ended
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
The root password set 216fbd36ec0bca18 successuful
1
Warning: Using a password on the command line interface can be insecure.
|-Successify --- Command executed! ---`
