Hi Still getting same error.
How to Fix Nginx WordPress Invalid JSON Response Or Permalinks 404 Error
Hello, I suggest you provide more information or screenshots. I can’t tell what the problem is.
Is your website open? Can the backend of the website be opened?
Hello Yes, I access the the backend and other all servercie https://reelsaver.io/blog/
Only not able to publish blog and pages.
Hello, it may be that the URL rewirte is not configured correctly. How did you build the website?
I have downloaded WordPress zip and upload on server then unzipped and create database .
Rewrite rules Do you need to add blog? This specifically depends on how your website is deployed.
Yes only on blog,
Hello, is it possible to try to modify the permanent link in the background of the website?
Just Add it on Config not URL rewrite
location / {try_files $uri $uri/ /index.php?$args;}
Try to update, but getting this error:
Hello, would you like to add the content of line 52? Please check whether the configuration of the relevant site is configured correctly.
This Is For Your Root
location / {
index index.php index.html index.htm;
If You Change link
location /post {
techthelearn The location of the same URL cannot be given twice
Hi, I have checked, when I choose plain in the permalink then its working fine and when I choose post name then getting same error - Publishing failed. The response is not a valid JSON response.
