# version=81
#./configure --with-php-config=/www/server/php/$version/bin/php-config
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for a sed that does not truncate output... /usr/bin/sed
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for cc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking how to run the C preprocessor... cc -E
checking for icc... no
checking for suncc... no
checking for system library directory... lib
checking if compiler supports -Wl,-rpath,... yes
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... x86_64-pc-linux-gnu
checking for PHP prefix... /www/server/php/81
checking for PHP includes... -I/www/server/php/81/include/php -I/www/server/php/81/include/php/main -I/www/server/php/81/include/php/TSRM -I/www/server/php/81/include/php/Zend -I/www/server/php/81/include/php/ext -I/www/server/php/81/include/php/ext/date/lib
checking for PHP extension directory... /www/server/php/81/lib/php/extensions/no-debug-non-zts-20210902
checking for PHP installed headers prefix... /www/server/php/81/include/php
checking if debug is enabled... no
checking if zts is enabled... no
checking for gawk... gawk
checking whether to enable the gmagick extension... yes, shared
checking GraphicsMagick configuration program... configure: error: not found. Please provide a path to GraphicsMagick-config program.
Hello aaPanel_Kern there is a progress after use your advice.
But still show error ....
