Balaji how to install ioncube loader in php8.2 my server configurations are Ubuntu 22.04.1 LTS x86_64(Py3.7.8) aapache
aaPanel_Kern Balaji try: wget https://node.aapanel.com/install/3/ioncube.sh bash ioncube.sh install 82
Balaji not solved with this method i am gettig this error on my site 'Script error: the ionCube Loader for PHP needs to be installed. The ionCube Loader is the industry standard PHP extension for running protected PHP code, and can usually be added easily to a PHP installation. For Loaders please visit get-loader.ioncube.com and for an instructional video please see http://ioncu.be/LV'
aaPanel_Kern Hello, what is the architecture of your cpu? If it is arm/aarch64, you need to install it manually. Balaji
aaPanel_Kern Hello, please check if the installation is successful? wget https://node.aapanel.com/install/3/ioncube.sh bash ioncube.sh install 82 Balaji
Balaji i tried this but then also this error is comming "'Script error: the ionCube Loader for PHP needs to be installed. The ionCube Loader is the industry standard PHP extension for running protected PHP code, and can usually be added easily to a PHP installation. For Loaders please visit get-loader.ioncube.com and for an instructional video please see http://ioncu.be/LV'"
aaPanel_Kern It is recommended to paste the results. If it does not work properly, it is recommended that you install this extension manually. Balaji
aaPanel_Kern Hi, I suggest you install it manually first. Download the files related to your operating system from the official website, https://www.ioncube.com/loaders.php And refer to the installation script to install Put the so file of the corresponding php version into /usr/local/ioncube/ and then add configuration content to the corresponding php version configuration file Such as the so file of php8.2: /usr/local/ioncube/ioncube_loader_lin_8.2.so The configuration file adds: ;ionCube zend_extension = /usr/local/ioncube/ioncube_loader_lin_8.2.so Install script: /www/server/panel/install/ioncube.sh
Balaji i have all the things u guided but when run this command "Install script: /www/server/panel/install/ioncube.sh"
aaP_shohan 2024-05-08 10:13:15 (23.7 MB/s) - ‘ioncube.sh.1’ saved [2219/2219] root@static:~# bash ioncube.sh install 82 php-8.2 已安装过ioncube,请选择其它版本! php-8.2 not install, Plese select other version! root@static:~#
