I have a remote db of postgresql i want to connect through add remote db option in pgsql in database tab in sidebar, but it's not working it's throwing error
{'status': False, 'msg': 'Connecting to remote PGSQL fails. Perform the following operations to rectify the fault:
1、The database port is correct and the firewall allows access
2、Check whether the database account password is correct
3、pg_hba.confWhether to add a client release record
4、postgresql.conf Add listen_addresses to the correct server IP address.'}
but when i am connecting with php it's working fine.
