ethicks I just Surprised that php.ini is not working even after restarting the php and apache server As you can see below that php.ini pgsql is enabled and saved here you can see the lib pgsql is not loaded and this is the php error thrown by php
aaPanel_Kern Hello, please restore the configuration and install the pgsql extension in the installation extension interface. ethicks
ethicks aaPanel_Kern I installed from extensions options and it automatically enabled the pdo_pgsql but i want only pgsql only how to enable that because in extensions options there are no pgsql is there
ethicks aaPanel_Kern It's different pdo_pgsql library is PHP Data Object pgsql which we get data from database in Object format but in pgsql library is a procedural method where we get data in array or multidimensional array format.
