Alehandro Hello, I added domain, but still warning at lock and needed to add exemption. I try later add domain to list and create Letsencrypt in panel but not help. Is there any manual?
aaPanel_Kern Hello, is it a website or aapanel? If it is aapanel, please modify the SSL configuration and use the corresponding domain name to access
aaPanel_Kern Alehandro Hello, it is recommended that you apply for SSL on the website first, and then set up SSL for the panel.
