bogdanr Hello, ssl renew script showing that i do not have any certificates that expires in 30 days. But if I checking manually, i have several. Also, please share script for ssl renew, i can not find it in cron
aaPanel_Kern Hello, please check whether the certificate applied for is operated by aapanel? Only supports Let's Encrypt applied by aapanel. The SSL renewal script is located in the Cron renewal task
