ranggaAP so I have this express project. It ran well yesterday yet now it happened to be like this. I just change its controller not the index file
ranggaAP aaPanel_Kern I did but it turned out like this I have one more project there and it runs just fine
aaPanel_Kern Please use the full path to the node command as: /www/server/nodejs/v18.16.0/bin/node ranggaAP
ranggaAP aaPanel_Kern sorry for late reply. I have found the solution. It seems someone restart the node version manager, that the command line ver got null. Thanks for your help anyway
aaP_trucept.lb ranggaAP i have same issue. i can't run nodejs. always "failed to activate" error. how did you fix it ?
