aaP_slewrate Hi, I've installed sheid1309/aapanel:latest on docker on macOS (m3). How do I access aaPanel via browser? localhost:8888 doesn't work. thanks Alex
aaPanel_Kern Hello, I suggest you check whether the command to create the container maps the relevant port. Does the relevant firewall have open ports? Are the containers running properly? aaP_slewrate
aaP_slewrate Hi there, I managed to setup a dev environment with OrbStack, works excellent. Thanks Alex
