*** System restart required ***
Last login: Mon Feb 26 15:48:45 2024 from 191.188.65.150
ubuntu@instance-20240226-1544:~$ curl -v https://brandnew.aapanel.com
- Trying 172.67.171.7:443...
- Connected to brandnew.aapanel.com (172.67.171.7) port 443 (#0)
- ALPN, offering h2
- ALPN, offering http/1.1
- CAfile: /etc/ssl/certs/ca-certificates.crt
- CApath: /etc/ssl/certs
- TLSv1.0 (OUT), TLS header, Certificate Status (22):
- TLSv1.3 (OUT), TLS handshake, Client hello (1):
- TLSv1.2 (IN), TLS header, Certificate Status (22):
- TLSv1.3 (IN), TLS handshake, Server hello (2):
- TLSv1.2 (IN), TLS header, Finished (20):
- TLSv1.2 (IN), TLS header, Supplemental data (23):
- TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
- TLSv1.3 (IN), TLS handshake, Certificate (11):
- TLSv1.3 (IN), TLS handshake, CERT verify (15):
- TLSv1.3 (IN), TLS handshake, Finished (20):
- TLSv1.2 (OUT), TLS header, Finished (20):
- TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
- TLSv1.2 (OUT), TLS header, Supplemental data (23):
- TLSv1.3 (OUT), TLS handshake, Finished (20):
- SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
- ALPN, server accepted to use h2
- Server certificate:
- subject: CN=aapanel.com
- start date: Jan 5 04:29:34 2024 GMT
- expire date: Apr 4 04:29:33 2024 GMT
- subjectAltName: host "brandnew.aapanel.com" matched cert's "*.aapanel.com"
- issuer: C=US; O=Google Trust Services LLC; CN=GTS CA 1P5
- SSL certificate verify ok.
- Using HTTP2, server supports multiplexing
- Connection state changed (HTTP/2 confirmed)
- Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
- Using Stream ID: 1 (easy handle 0xaaab1a9c8cc0)
GET / HTTP/2
Host: brandnew.aapanel.com
user-agent: curl/7.81.0
accept: /
- TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
- old SSL session ID is stale, removing
< HTTP/2 302
< date: Thu, 29 Feb 2024 14:53:30 GMT
< content-type: text/html; charset=UTF-8
< location: /new/index.html
< cache-control: no-cache, private
< set-cookie: XSRF-TOKEN=eyJpdiI6IlVSSjY3NE9OUy90WCt5WC8vT0tVNkE9PSIsInZhbHVlIjoid0xSa1ZjV0kxc0pMZlVNVXZuYTlYWGV6Ym53UG4rSEJ4NHJpTDNuNTNIaUgzZ1E0QVpGczFEcVBOQWpnVzRSbDhiTStQODNWL0hwMjVwRE8wdHZwUFAvOUtVeG43SGFlL0NlZ0QvRFRMQzROcTdlRVNiZ2ZzU1BvVjZFb0ViWVMiLCJtYWMiOiI4Njg1ODVhNzIxNjdhZTg0MzA5ZTEwNjU0MWRlNDAzNWQ2NTQ1MmZhZWI2NjQ2OTFmMjI3MjVlYWJmNDI3NmE0IiwidGFnIjoiIn0%3D; expires=Thu, 29-Feb-2024 16:53:30 GMT; Max-Age=7200; path=/; samesite=lax
< set-cookie: aapanel_session=eyJpdiI6Ild3Tng0blB1cVhwMEhoOHgzSTFVV0E9PSIsInZhbHVlIjoib043ODJIRnVFK0tvUElSTHhNZlNLcTgxL0dWdHYwUmJZeGdlOGF2UE5QcWZkT3p1U2hPYTM4dDExSmtjM2VWczNjanlld3JxTWN4NGFvZXRKdlpMVTZyVkpZVG45UEh0bzRBQXF1MlNoV0J6cURiMWRoM0tZUE9HZ3p2a1JuZWoiLCJtYWMiOiIwMTc4ZTBjNjNiNjQyMGUxOTY5YjY4ZGUyYWNlOTVhOTgwYzgwNDRiNTJjNmI0NDgzYWQ0M2JlMzJiNmMyZTg2IiwidGFnIjoiIn0%3D; expires=Thu, 29-Feb-2024 16:53:30 GMT; Max-Age=7200; path=/; httponly; samesite=lax
< strict-transport-security: max-age=63072000
< cf-cache-status: DYNAMIC
< report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=ay7MI3L2y267e0uAdzl9vb7P10PHU8riWRmFV62ZUBTOBRTdOdTWPzEoReeeG2izqaVFjse3skJAh%2FroawpCiX%2BiEJppI9ikreUnwvKy1GQ604pVw8RNKiyfnbqFqIdBnBKeVf7SDQ%3D%3D"}],"group":"cf-nel","max_age":604800}
< nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
< server: cloudflare
< cf-ray: 85d1bcb27be70292-GRU
< alt-svc: h3=":443"; ma=86400
- Connection #0 to host brandnew.aapanel.com left intact
ubuntu@instance-20240226-1544:~$ ping brandnew.aapanel.com -c 5
PING brandnew.aapanel.com (104.21.79.196) 56(84) bytes of data.
64 bytes from 104.21.79.196 (104.21.79.196): icmp_seq=1 ttl=61 time=1.95 ms
64 bytes from 104.21.79.196 (104.21.79.196): icmp_seq=2 ttl=61 time=2.06 ms
64 bytes from 104.21.79.196 (104.21.79.196): icmp_seq=3 ttl=61 time=2.00 ms
64 bytes from 104.21.79.196 (104.21.79.196): icmp_seq=4 ttl=61 time=1.99 ms
64 bytes from 104.21.79.196 (104.21.79.196): icmp_seq=5 ttl=61 time=1.96 ms
--- brandnew.aapanel.com ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4007ms
rtt min/avg/max/mdev = 1.948/1.992/2.059/0.038 ms
ubuntu@instance-20240226-1544:~$ ping google.com -c 5
PING google.com (142.250.218.174) 56(84) bytes of data.
64 bytes from gru06s62-in-f14.1e100.net (142.250.218.174): icmp_seq=1 ttl=119 time=2.00 ms
64 bytes from gru06s62-in-f14.1e100.net (142.250.218.174): icmp_seq=2 ttl=119 time=2.06 ms
64 bytes from gru06s62-in-f14.1e100.net (142.250.218.174): icmp_seq=3 ttl=119 time=2.02 ms
64 bytes from gru06s62-in-f14.1e100.net (142.250.218.174): icmp_seq=4 ttl=119 time=2.04 ms
64 bytes from gru06s62-in-f14.1e100.net (142.250.218.174): icmp_seq=5 ttl=119 time=2.00 ms
--- google.com ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4006ms
rtt min/avg/max/mdev = 1.996/2.021/2.057/0.023 ms
ubuntu@instance-20240226-1544:~$ curl -v http://brandnew.aapanel.com
- Trying 172.67.171.7:80...
- Connected to brandnew.aapanel.com (172.67.171.7) port 80 (#0)
GET / HTTP/1.1
User-Agent: curl/7.81.0
Accept: /
- Mark bundle as not supporting multiuse
< HTTP/1.1 301 Moved Permanently
< Date: Thu, 29 Feb 2024 14:53:55 GMT
< Content-Type: text/html
< Transfer-Encoding: chunked
< Connection: keep-alive
< Location: https://brandnew.aapanel.com/
< Strict-Transport-Security: max-age=63072000
< CF-Cache-Status: DYNAMIC
< Report-To: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=8eNICusqUsLfMSLg6vomVajN7iqtjXsoi35%2Fb7%2FgKQn6Frj3cE%2FSuLS9qCl3rVmG69Pz4YvVDAc6Lg2gHo6z7k81pNttvfQZ9ua8M9uStYYJm1O9dogqAHQpf3E8WIV2eixYmVJLXQ%3D%3D"}],"group":"cf-nel","max_age":604800}
< NEL: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
< Server: cloudflare
< CF-RAY: 85d1bd54993b1af5-GRU
<html>
<head><title>301 Moved Permanently</title></head>
<body>
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx</center>
</body>
</html>
