aaP_slewrate
Ubuntu 22.04 LTS is the best OS you can choose if you wanna install AA-Panel (stable) and other Linux applications on your server. This is the OS I dailydrive on my machines and since it is (one of) the biggest you will find the most help/support for it. I can only recommend you to use it on your Linux server.
~ Aoinu
