when install mongo db show is seccess
but log
{"t":{"$date":"2024-02-20T18:53:47.740+01:00"},"s":"I", "c":"NETWORK", "id":4915701, "ctx":"-","msg":"Initialized wire specification","attr":{"spec":{"incomingExternalClient":{"minWireVersion":0,"maxWireVersion":17},"incomingInternalClient":{"minWireVersion":0,"maxWireVersion":17},"outgoing":{"minWireVersion":6,"maxWireVersion":17},"isInternalClient":true}}}
{"t":{"$date":"2024-02-20T18:53:47.744+01:00"},"s":"I", "c":"CONTROL", "id":23285, "ctx":"main","msg":"Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'"}
{"t":{"$date":"2024-02-20T18:53:47.744+01:00"},"s":"I", "c":"NETWORK", "id":4648601, "ctx":"main","msg":"Implicit TCP FastOpen unavailable. If TCP FastOpen is required, set tcpFastOpenServer, tcpFastOpenClient, and tcpFastOpenQueueSize."}
{"t":{"$date":"2024-02-20T18:53:47.747+01:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"TenantMigrationDonorService","namespace":"config.tenantMigrationDonors"}}
{"t":{"$date":"2024-02-20T18:53:47.747+01:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"TenantMigrationRecipientService","namespace":"config.tenantMigrationRecipients"}}
{"t":{"$date":"2024-02-20T18:53:47.747+01:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"ShardSplitDonorService","namespace":"config.tenantSplitDonors"}}
{"t":{"$date":"2024-02-20T18:53:47.747+01:00"},"s":"I", "c":"CONTROL", "id":5945603, "ctx":"main","msg":"Multi threading initialized"}
{"t":{"$date":"2024-02-20T18:53:47.748+01:00"},"s":"I", "c":"CONTROL", "id":4615611, "ctx":"initandlisten","msg":"MongoDB starting","attr":{"pid":4026788,"port":27017,"dbPath":"/www/server/mongodb/data","architecture":"64-bit","host":"vmi206003.contaboserver.net"}}
{"t":{"$date":"2024-02-20T18:53:47.748+01:00"},"s":"I", "c":"CONTROL", "id":23403, "ctx":"initandlisten","msg":"Build Info","attr":{"buildInfo":{"version":"6.0.10","gitVersion":"8e4b5670df9b9fe814e57cb5f3f8ee9407237b5a","openSSLVersion":"OpenSSL 1.1.1k FIPS 25 Mar 2021","modules":[],"allocator":"tcmalloc","environment":{"distmod":"rhel80","distarch":"x86_64","target_arch":"x86_64"}}}}
{"t":{"$date":"2024-02-20T18:53:47.748+01:00"},"s":"I", "c":"CONTROL", "id":51765, "ctx":"initandlisten","msg":"Operating System","attr":{"os":{"name":"CentOS Stream release 8","version":"Kernel 4.18.0-365.el8.x86_64"}}}
{"t":{"$date":"2024-02-20T18:53:47.748+01:00"},"s":"I", "c":"CONTROL", "id":21951, "ctx":"initandlisten","msg":"Options set by command line","attr":{"options":{"config":"/www/server/mongodb/config.conf","net":{"bindIp":"127.0.0.1","port":27017},"processManagement":{"fork":true,"pidFilePath":"/www/server/mongodb/log/configsvr.pid"},"security":{"authorization":"disabled","javascriptEnabled":false},"storage":{"dbPath":"/www/server/mongodb/data","directoryPerDB":true,"journal":{"enabled":true}},"systemLog":{"destination":"file","logAppend":true,"path":"/www/server/mongodb/log/config.log"}}}}
{"t":{"$date":"2024-02-20T18:53:47.748+01:00"},"s":"E", "c":"NETWORK", "id":23024, "ctx":"initandlisten","msg":"Failed to unlink socket file","attr":{"path":"/tmp/mongodb-27017.sock","error":"Operation not permitted"}}
{"t":{"$date":"2024-02-20T18:53:47.748+01:00"},"s":"F", "c":"ASSERT", "id":23091, "ctx":"initandlisten","msg":"Fatal assertion","attr":{"msgid":40486,"file":"src/mongo/transport/transport_layer_asio.cpp","line":1130}}
{"t":{"$date":"2024-02-20T18:53:47.748+01:00"},"s":"F", "c":"ASSERT", "id":23092, "ctx":"initandlisten","msg":"\n\n***aborting after fassert() failure\n\n"}
{"t":{"$date":"2024-02-20T18:54:08.626+01:00"},"s":"I", "c":"CONTROL", "id":20698, "ctx":"-","msg":"***** SERVER RESTARTED **"}
{"t":{"$date":"2024-02-20T18:54:08.629+01:00"},"s":"I", "c":"NETWORK", "id":4915701, "ctx":"-","msg":"Initialized wire specification","attr":{"spec":{"incomingExternalClient":{"minWireVersion":0,"maxWireVersion":17},"incomingInternalClient":{"minWireVersion":0,"maxWireVersion":17},"outgoing":{"minWireVersion":6,"maxWireVersion":17},"isInternalClient":true}}}
{"t":{"$date":"2024-02-20T18:54:08.632+01:00"},"s":"I", "c":"CONTROL", "id":23285, "ctx":"main","msg":"Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'"}
{"t":{"$date":"2024-02-20T18:54:08.633+01:00"},"s":"I", "c":"NETWORK", "id":4648601, "ctx":"main","msg":"Implicit TCP FastOpen unavailable. If TCP FastOpen is required, set tcpFastOpenServer, tcpFastOpenClient, and tcpFastOpenQueueSize."}
{"t":{"$date":"2024-02-20T18:54:08.635+01:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"TenantMigrationDonorService","namespace":"config.tenantMigrationDonors"}}
{"t":{"$date":"2024-02-20T18:54:08.635+01:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"TenantMigrationRecipientService","namespace":"config.tenantMigrationRecipients"}}
{"t":{"$date":"2024-02-20T18:54:08.635+01:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"ShardSplitDonorService","namespace":"config.tenantSplitDonors"}}
{"t":{"$date":"2024-02-20T18:54:08.636+01:00"},"s":"I", "c":"CONTROL", "id":5945603, "ctx":"main","msg":"Multi threading initialized"}
{"t":{"$date":"2024-02-20T18:54:08.636+01:00"},"s":"I", "c":"CONTROL", "id":4615611, "ctx":"initandlisten","msg":"MongoDB starting","attr":{"pid":4027155,"port":27017,"dbPath":"/www/server/mongodb/data","architecture":"64-bit","host":"vmi206003.contaboserver.net"}}
{"t":{"$date":"2024-02-20T18:54:08.636+01:00"},"s":"I", "c":"CONTROL", "id":23403, "ctx":"initandlisten","msg":"Build Info","attr":{"buildInfo":{"version":"6.0.10","gitVersion":"8e4b5670df9b9fe814e57cb5f3f8ee9407237b5a","openSSLVersion":"OpenSSL 1.1.1k FIPS 25 Mar 2021","modules":[],"allocator":"tcmalloc","environment":{"distmod":"rhel80","distarch":"x86_64","target_arch":"x86_64"}}}}
{"t":{"$date":"2024-02-20T18:54:08.636+01:00"},"s":"I", "c":"CONTROL", "id":51765, "ctx":"initandlisten","msg":"Operating System","attr":{"os":{"name":"CentOS Stream release 8","version":"Kernel 4.18.0-365.el8.x86_64"}}}
{"t":{"$date":"2024-02-20T18:54:08.636+01:00"},"s":"I", "c":"CONTROL", "id":21951, "ctx":"initandlisten","msg":"Options set by command line","attr":{"options":{"config":"/www/server/mongodb/config.conf","net":{"bindIp":"127.0.0.1","port":27017},"processManagement":{"fork":true,"pidFilePath":"/www/server/mongodb/log/configsvr.pid"},"security":{"authorization":"disabled","javascriptEnabled":false},"storage":{"dbPath":"/www/server/mongodb/data","directoryPerDB":true,"journal":{"enabled":true}},"systemLog":{"destination":"file","logAppend":true,"path":"/www/server/mongodb/log/config.log"}}}}
{"t":{"$date":"2024-02-20T18:54:08.637+01:00"},"s":"E", "c":"NETWORK", "id":23024, "ctx":"initandlisten","msg":"Failed to unlink socket file","attr":{"path":"/tmp/mongodb-27017.sock","error":"Operation not permitted"}}
{"t":{"$date":"2024-02-20T18:54:08.637+01:00"},"s":"F", "c":"ASSERT", "id":23091, "ctx":"initandlisten","msg":"Fatal assertion","attr":{"msgid":40486,"file":"src/mongo/transport/transport_layer_asio.cpp","line":1130}}
{"t":{"$date":"2024-02-20T18:54:08.637+01:00"},"s":"F", "c":"ASSERT", "id":23092, "ctx":"initandlisten","msg":"\n\naborting after fassert() failure\n\n"}
