today get money error for test send to @yahoo.com and @gmail.com elso @hotmail.com
how can get fix
postfix/anvil
postfix/submission/smtpd
lost connection
disconnect from unknown
statistics: max connection
statistics: max cache size
imap-login: Disconnected: Connection closed
pop3-login: Disconnected: Connection closed
TLS handshaking: Connection closed, session
TLS handshaking: SSL_accept() failed: error
warning: hostname internettl.org does not resolve to address
warning: TLS library problem: error
SSL_accept error from unknown
Feb 24 07:24:52 @A@ postfix/anvil[216589]: statistics: max cache size 2 at Feb 24 07:21:18
Feb 24 07:28:25 @A@ postfix/submission/smtpd[216614]: connect from unknown[164.215.103.189]
Feb 24 07:28:25 @A@ postfix/submission/smtpd[216614]: disconnect from unknown[164.215.103.189] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 24 07:29:55 @A@ postfix/smtps/smtpd[216622]: connect from c193-13-168-231.bredband.tele2.se[193.13.168.231]
Feb 24 07:30:04 @A@ postfix/smtps/smtpd[216622]: warning: c193-13-168-231.bredband.tele2.se[193.13.168.231]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 07:30:05 @A@ postfix/smtps/smtpd[216622]: lost connection after AUTH from c193-13-168-231.bredband.tele2.se[193.13.168.231]
Feb 24 07:30:05 @A@ postfix/smtps/smtpd[216622]: disconnect from c193-13-168-231.bredband.tele2.se[193.13.168.231] ehlo=1 auth=0/1 commands=1/2
Feb 24 07:30:07 @A@ postfix/smtps/smtpd[216622]: connect from unknown[39.164.151.143]
Feb 24 07:30:19 @A@ postfix/smtps/smtpd[216622]: warning: unknown[39.164.151.143]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 07:30:20 @A@ postfix/smtps/smtpd[216622]: lost connection after AUTH from unknown[39.164.151.143]
Feb 24 07:30:20 @A@ postfix/smtps/smtpd[216622]: disconnect from unknown[39.164.151.143] ehlo=1 auth=0/1 commands=1/2
Feb 24 07:33:40 @A@ postfix/anvil[216616]: statistics: max connection rate 1/60s for (submission:164.215.103.189) at Feb 24 07:28:25
Feb 24 07:33:40 @A@ postfix/anvil[216616]: statistics: max connection count 1 for (submission:164.215.103.189) at Feb 24 07:28:25
Feb 24 07:33:40 @A@ postfix/anvil[216616]: statistics: max cache size 2 at Feb 24 07:30:10
Feb 24 07:33:44 @A@ postfix/submission/smtpd[216644]: connect from unknown[101.43.13.67]
Feb 24 07:33:45 @A@ postfix/submission/smtpd[216644]: disconnect from unknown[101.43.13.67] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 24 07:37:05 @A@ postfix/anvil[216646]: statistics: max connection rate 1/60s for (submission:101.43.13.67) at Feb 24 07:33:44
Feb 24 07:37:05 @A@ postfix/anvil[216646]: statistics: max connection count 1 for (submission:101.43.13.67) at Feb 24 07:33:44
Feb 24 07:37:05 @A@ postfix/anvil[216646]: statistics: max cache size 1 at Feb 24 07:33:44
Feb 24 07:41:47 @A@ postfix/smtps/smtpd[216673]: warning: hostname vipturbo.com.br does not resolve to address 191.36.152.41
Feb 24 07:41:47 @A@ postfix/smtps/smtpd[216673]: connect from unknown[191.36.152.41]
Feb 24 07:41:57 @A@ postfix/smtps/smtpd[216673]: warning: unknown[191.36.152.41]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 07:41:58 @A@ postfix/smtps/smtpd[216673]: lost connection after AUTH from unknown[191.36.152.41]
Feb 24 07:41:58 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[191.36.152.41] ehlo=1 auth=0/1 commands=1/2
Feb 24 07:41:59 @A@ postfix/smtps/smtpd[216673]: connect from unknown[91.90.98.102]
Feb 24 07:42:06 @A@ postfix/smtps/smtpd[216673]: warning: unknown[91.90.98.102]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 07:42:06 @A@ postfix/smtps/smtpd[216673]: lost connection after AUTH from unknown[91.90.98.102]
Feb 24 07:42:06 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[91.90.98.102] ehlo=1 auth=0/1 commands=1/2
Feb 24 07:42:20 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, session=<Gv/WIxoSUr5omDQP>
Feb 24 07:42:20 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: read(size=1026) failed: Connection reset by peer (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: read(size=1026) failed: Connection reset by peer, session=<WjDZIxoSSaRomDQP>
Feb 24 07:42:20 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: read(size=1026) failed: Connection reset by peer (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: read(size=1026) failed: Connection reset by peer, session=<Xm7ZIxoSQ9BomDQP>
Feb 24 07:42:20 @A@ postfix/submission/smtpd[216685]: connect from unknown[unknown]
Feb 24 07:42:20 @A@ postfix/submission/smtpd[216685]: lost connection after CONNECT from unknown[unknown]
Feb 24 07:42:20 @A@ postfix/submission/smtpd[216685]: disconnect from unknown[unknown] commands=0/0
Feb 24 07:42:20 @A@ postfix/submission/smtpd[216685]: connect from unknown[164.215.103.189]
Feb 24 07:42:21 @A@ postfix/submission/smtpd[216685]: disconnect from unknown[164.215.103.189] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 24 07:42:21 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, session=<4APrIxoSn4tomDQP>
Feb 24 07:42:21 @A@ postfix/smtps/smtpd[216673]: connect from unknown[unknown]
Feb 24 07:42:21 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[unknown]: Connection reset by peer
Feb 24 07:42:21 @A@ postfix/smtps/smtpd[216673]: lost connection after CONNECT from unknown[unknown]
Feb 24 07:42:21 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[unknown] commands=0/0
Feb 24 07:42:23 @A@ postfix/smtps/smtpd[216673]: warning: hostname internettl.org does not resolve to address 104.152.52.15
Feb 24 07:42:23 @A@ postfix/smtps/smtpd[216673]: connect from unknown[104.152.52.15]
Feb 24 07:42:23 @A@ postfix/submission/smtpd[216685]: warning: hostname internettl.org does not resolve to address 104.152.52.15
Feb 24 07:42:23 @A@ postfix/submission/smtpd[216685]: connect from unknown[104.152.52.15]
Feb 24 07:42:23 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed (no auth attempts in 1 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, session=<KroFJBoSyZZomDQP>
Feb 24 07:42:23 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed (no auth attempts in 1 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, session=<2P4FJBoSMdNomDQP>
Feb 24 07:42:23 @A@ postfix/submission/smtpd[216685]: lost connection after CONNECT from unknown[104.152.52.15]
Feb 24 07:42:23 @A@ postfix/submission/smtpd[216685]: disconnect from unknown[104.152.52.15] commands=0/0
Feb 24 07:42:28 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F09C:SSL routines:ssl3_get_record:http request (no auth attempts in 6 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F09C:SSL routines:ssl3_get_record:http request, session=<zuxeJBoS6LdomDQP>
Feb 24 07:42:28 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F09C:SSL routines:ssl3_get_record:http request (no auth attempts in 6 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F09C:SSL routines:ssl3_get_record:http request, session=<+fReJBoS5ONomDQP>
Feb 24 07:42:29 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: read(size=1026) failed: Connection reset by peer (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: read(size=1026) failed: Connection reset by peer, session=<qAZkJBoSf6NomDQP>
Feb 24 07:42:29 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol, session=<TqNoJBoSa6VomDQP>
Feb 24 07:42:33 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: lost connection
Feb 24 07:42:33 @A@ postfix/smtps/smtpd[216673]: lost connection after CONNECT from unknown[104.152.52.15]
Feb 24 07:42:33 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[104.152.52.15] commands=0/0
Feb 24 07:42:34 @A@ postfix/smtps/smtpd[216673]: warning: hostname internettl.org does not resolve to address 104.152.52.15
Feb 24 07:42:34 @A@ postfix/smtps/smtpd[216673]: connect from unknown[104.152.52.15]
Feb 24 07:42:34 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: -1
Feb 24 07:42:34 @A@ postfix/smtps/smtpd[216673]: warning: TLS library problem: error:1408F09C:SSL routines:ssl3_get_record:http request:ssl/record/ssl3_record.c:322:
Feb 24 07:42:34 @A@ postfix/smtps/smtpd[216673]: lost connection after CONNECT from unknown[104.152.52.15]
Feb 24 07:42:34 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[104.152.52.15] commands=0/0
Feb 24 07:42:34 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed (no auth attempts in 5 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: Connection closed, session=<QhuwJBoSvOVomDQP>
Feb 24 07:42:34 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<j7GyJBoSK5xomDQP>
Feb 24 07:42:34 @A@ postfix/smtps/smtpd[216673]: warning: TLS library problem: error:1408F10B:SSL routines:ssl3_get_record:wrong version number:ssl/record/ssl3_record.c:332:
Feb 24 07:42:34 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<53e3JBoSd55omDQP>
Feb 24 07:42:34 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed (no auth attempts in 5 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: Connection closed, session=<Cd65JBoS0ahomDQP>
Feb 24 07:42:35 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL
routines:ssl3_get_record:wrong version number, session=<poG8JBoSXaBomDQP>
Feb 24 07:42:35 @A@ postfix/smtps/smtpd[216673]: warning: hostname internettl.org does not resolve to address 104.152.52.15
Feb 24 07:42:35 @A@ postfix/smtps/smtpd[216673]: connect from unknown[104.152.52.15]
Feb 24 07:42:35 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: -1
Feb 24 07:42:35 @A@ postfix/smtps/smtpd[216673]: warning: TLS library problem: error:1408F10B:SSL
Feb 24 07:42:35 @A@ postfix/smtps/smtpd[216673]: lost connection after CONNECT from unknown[104.152.52.15]
Feb 24 07:42:35 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[104.152.52.15] commands=0/0
Feb 24 07:42:35 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<1I+8JBoSWcxomDQP>
Feb 24 07:42:35 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<Xl7BJBoSoqNomDQP>
Feb 24 07:42:35 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<TobBJBoSoM9omDQP>
Feb 24 07:42:35 @A@ postfix/smtps/smtpd[216673]: warning: TLS library problem: error:1408F10B:SSL routines:ssl3_get_record:wrong version number:ssl/record/ssl3_record.c:332:
Feb 24 07:42:35 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<d0vGJBoSgKVomDQP>
Feb 24 07:42:35 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<TovGJBoSf9FomDQP>
Feb 24 07:42:36 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<miLLJBoSz6domDQP>
Feb 24 07:42:36 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<yYvLJBoS4dNomDQP>
Feb 24 07:42:36 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: read(size=1026) failed: Connection reset by peer (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: read(size=1026) failed: Connection reset by peer, session=<3urPJBoScqpomDQP>
Feb 24 07:42:36 @A@ postfix/smtps/smtpd[216673]: warning: hostname internettl.org does not resolve to address 104.152.52.15
Feb 24 07:42:36 @A@ postfix/smtps/smtpd[216673]: connect from unknown[104.152.52.15]
Feb 24 07:42:36 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: -1
Feb 24 07:42:36 @A@ postfix/smtps/smtpd[216673]: warning: TLS library problem: error:1408F10B:SSL routines:ssl3_get_record:wrong version number:ssl/record/ssl3_record.c:332:
Feb 24 07:42:36 @A@ postfix/smtps/smtpd[216673]: lost connection after CONNECT from unknown[104.152.52.15]
Feb 24 07:42:36 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[104.152.52.15] commands=0/0
Feb 24 07:42:36 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<WovQJBoSptZomDQP>
Feb 24 07:42:36 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<ZIfUJBoS7KxomDQP>
Feb 24 07:42:36 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<UGbVJBoSNdlomDQP>
Feb 24 07:42:36 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<k5XZJBoSVa9omDQP>
Feb 24 07:42:37 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<im3aJBoSk9tomDQP>
Feb 24 07:42:37 @A@ postfix/smtps/smtpd[216673]: warning: hostname internettl.org does not resolve to address 104.152.52.15
Feb 24 07:42:37 @A@ postfix/smtps/smtpd[216673]: connect from unknown[104.152.52.15]
Feb 24 07:42:37 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: Connection reset by peer
Feb 24 07:42:37 @A@ postfix/smtps/smtpd[216673]: lost connection after CONNECT from unknown[104.152.52.15]
Feb 24 07:42:37 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[104.152.52.15] commands=0/0
Feb 24 07:42:37 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: read(size=1026) failed: Connection reset by peer (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: read(size=1026) failed: Connection reset by peer, session=<cI/eJBoS0bFomDQP>
Feb 24 07:42:37 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<j2nfJBoSN95omDQP>
Feb 24 07:42:37 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: -1
Feb 24 07:42:37 @A@ postfix/smtps/smtpd[216673]: warning: TLS library problem: error:1408F10B:SSL routines:ssl3_get_record:wrong version number:ssl/record/ssl3_record.c:332:
Feb 24 07:42:37 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<lyPjJBoSdrRomDQP>
Feb 24 07:42:37 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: read(size=1026) failed: Connection reset by peer (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: read(size=1026) failed: Connection reset by peer, session=<qjXkJBoS5OBomDQP>
Feb 24 07:42:37 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<EAboJBoSGrdomDQP>
Feb 24 07:42:37 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<2+roJBoS3+NomDQP>
Feb 24 07:42:38 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: read(size=1026) failed: Connection reset by peer (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: read(size=1026) failed: Connection reset by peer, session=<SAvtJBoSU7pomDQP>
Feb 24 07:42:38 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<dqztJBoS9+ZomDQP>
Feb 24 07:42:38 @A@ postfix/smtps/smtpd[216673]: warning: hostname internettl.org does not resolve to address 104.152.52.15
Feb 24 07:42:38 @A@ postfix/smtps/smtpd[216673]: connect from unknown[104.152.52.15]
Feb 24 07:42:38 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: Connection reset by peer
Feb 24 07:42:38 @A@ postfix/smtps/smtpd[216673]: lost connection after CONNECT from unknown[104.152.52.15]
Feb 24 07:42:38 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[104.152.52.15] commands=0/0
Feb 24 07:42:38 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: read(size=1026) failed: Connection reset by peer (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: read(size=1026) failed: Connection reset by peer, session=<FcDxJBoSLL1omDQP>
Feb 24 07:42:38 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: read(size=1026) failed: Connection reset by peer (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: read(size=1026) failed: Connection reset by peer, session=<TYDyJBoSpOlomDQP>
Feb 24 07:42:38 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: -1
Feb 24 07:42:38 @A@ postfix/smtps/smtpd[216673]: warning: TLS library problem: error:1408F10B:SSL routines:ssl3_get_record:wrong version number:ssl/record/ssl3_record.c:332:
Feb 24 07:42:38 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<VGv2JBoSWMBomDQP>
Feb 24 07:42:38 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: read(size=1026) failed: Connection reset by peer (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: read(size=1026) failed: Connection reset by peer, session=<+ET3JBoShOxomDQP>
Feb 24 07:42:39 @A@ postfix/smtps/smtpd[216673]: warning: hostname internettl.org does not resolve to address 104.152.52.15
Feb 24 07:42:39 @A@ postfix/smtps/smtpd[216673]: connect from unknown[104.152.52.15]
Feb 24 07:42:39 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: -1
Feb 24 07:42:39 @A@ postfix/smtps/smtpd[216673]: warning: TLS library problem: error:1408F10B:SSL routines:ssl3_get_record:wrong version number:ssl/record/ssl3_record.c:332:
Feb 24 07:42:39 @A@ postfix/smtps/smtpd[216673]: lost connection after CONNECT from unknown[104.152.52.15]
Feb 24 07:42:39 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[104.152.52.15] commands=0/0
Feb 24 07:42:39 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<ulr7JBoSfsJomDQP>
Feb 24 07:42:39 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<0bb7JBoSuIBomDQP>
Feb 24 07:42:39 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<W2oAJRoSzMRomDQP>
Feb 24 07:42:39 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<ZnoAJRoSjoJomDQP>
Feb 24 07:42:39 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: Connection reset by peer
Feb 24 07:42:39 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<C3IFJRoStYRomDQP>
Feb 24 07:42:39 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<2HQFJRoS/8ZomDQP>
Feb 24 07:42:40 @A@ postfix/smtps/smtpd[216673]: warning: hostname internettl.org does not resolve to address 104.152.52.15
Feb 24 07:42:40 @A@ postfix/smtps/smtpd[216673]: connect from unknown[104.152.52.15]
Feb 24 07:42:40 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: -1
Feb 24 07:42:40 @A@ postfix/smtps/smtpd[216673]: warning: TLS library problem: error:1408F10B:SSL routines:ssl3_get_record:wrong version number:ssl/record/ssl3_record.c:332:
Feb 24 07:42:40 @A@ postfix/smtps/smtpd[216673]: lost connection after CONNECT from unknown[104.152.52.15]
Feb 24 07:42:40 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[104.152.52.15] commands=0/0
Feb 24 07:42:40 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<6DAKJRoSKYdomDQP>
Feb 24 07:42:40 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<0nEKJRoSaclomDQP>
Feb 24 07:42:40 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (no auth attempts in 0 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<qSEPJRoS3IlomDQP>
Feb 24 07:42:41 @A@ postfix/smtps/smtpd[216673]: warning: hostname internettl.org does not resolve to address 104.152.52.15
Feb 24 07:42:41 @A@ postfix/smtps/smtpd[216673]: connect from unknown[104.152.52.15]
Feb 24 07:42:41 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: -1
Feb 24 07:42:41 @A@ postfix/smtps/smtpd[216673]: warning: TLS library problem: error:1408F10B:SSL routines:ssl3_get_record:wrong version number:ssl/record/ssl3_record.c:332:
Feb 24 07:42:41 @A@ postfix/smtps/smtpd[216673]: lost connection after CONNECT from unknown[104.152.52.15]
Feb 24 07:42:41 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[104.152.52.15] commands=0/0
Feb 24 07:42:42 @A@ postfix/smtps/smtpd[216673]: warning: hostname internettl.org does not resolve to address 104.152.52.15
Feb 24 07:42:42 @A@ postfix/smtps/smtpd[216673]: connect from unknown[104.152.52.15]
Feb 24 07:42:45 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed (no auth attempts in 5 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: Connection closed, session=<I3NbJRoSTsxomDQP>
Feb 24 07:42:45 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed (no auth attempts in 5 secs): user=<>, rip=104.152.52.15, lip=00.00.00.00, TLS handshaking: Connection closed, session=<LRtgJRoSmYxomDQP>
Feb 24 07:42:47 @A@ postfix/smtps/smtpd[216673]: SSL_accept error from unknown[104.152.52.15]: lost connection
Feb 24 07:42:47 @A@ postfix/smtps/smtpd[216673]: lost connection after CONNECT from unknown[104.152.52.15]
Feb 24 07:42:47 @A@ postfix/smtps/smtpd[216673]: disconnect from unknown[104.152.52.15] commands=0/0
Feb 24 07:46:07 @A@ postfix/anvil[216678]: statistics: max connection rate 1/60s for (smtps:191.36.152.41) at Feb 24 07:41:50
Feb 24 07:46:07 @A@ postfix/anvil[216678]: statistics: max connection count 1 for (smtps:191.36.152.41) at Feb 24 07:41:50
Feb 24 07:46:07 @A@ postfix/anvil[216678]: statistics: max cache size 5 at Feb 24 07:42:23
Feb 24 07:50:37 @A@ postfix/qmgr[202820]: 1B9A610012B: from=<tester01@A2@>, size=550, nrcpt=1 (queue active)
Feb 24 07:50:37 @A@ postfix/qmgr[202820]: 4AA1810017A: from=<tester01@A2@>, size=521, nrcpt=1 (queue active)
Feb 24 07:50:37 @A@ postfix/smtp[216767]: connect to reception.mail-tester.com[94.23.206.89]:25: No route to host
Feb 24 07:50:37 @A@ postfix/smtp[216767]: 1B9A610012B: to=test-zleurf7g1@srv1.mail-tester.com, relay=none, delay=38301, delays=38301/0.05/0.19/0, dsn=4.4.1, status=deferred (connect to reception.mail-tester.com[94.23.206.89]:25: No route to host)
Feb 24 07:50:38 @A@ postfix/smtp[216768]: connect to gmail-smtp-in.l.google.com[2a00:1450:4013:c14::1b]:25: Network is unreachable
Feb 24 07:50:38 @A@ postfix/smtp[216768]: connect to gmail-smtp-in.l.google.com[142.250.145.27]:25: No route to host
Feb 24 07:50:38 @A@ postfix/smtp[216768]: connect to alt1.gmail-smtp-in.l.google.com[142.250.150.27]:25: No route to host
Feb 24 07:50:38 @A@ postfix/smtp[216768]: connect to alt1.gmail-smtp-in.l.google.com[2a00:1450:4010:c1c::1a]:25: Network is unreachable
Feb 24 07:50:38 @A@ postfix/smtp[216768]: connect to alt2.gmail-smtp-in.l.google.com[2404:6800:4003:c00::1a]:25: Network is unreachable
Feb 24 07:50:38 @A@ postfix/smtp[216768]: 4AA1810017A: to=tester02@gmail.com, relay=none, delay=38247, delays=38246/0.05/0.72/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[2404:6800:4003:c00::1a]:25: Network is unreachable)
Feb 24 07:55:13 @A@ postfix/submission/smtpd[216790]: connect from unknown[164.215.103.189]
Feb 24 07:55:13 @A@ postfix/submission/smtpd[216790]: disconnect from unknown[164.215.103.189] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 24 07:55:33 @A@ postfix/smtps/smtpd[216793]: connect from unknown[218.76.104.12]
Feb 24 07:55:44 @A@ postfix/smtps/smtpd[216793]: warning: unknown[218.76.104.12]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 07:55:45 @A@ postfix/smtps/smtpd[216793]: lost connection after AUTH from unknown[218.76.104.12]
Feb 24 07:55:45 @A@ postfix/smtps/smtpd[216793]: disconnect from unknown[218.76.104.12] ehlo=1 auth=0/1 commands=1/2
Feb 24 07:55:52 @A@ postfix/smtps/smtpd[216793]: connect from host150.sub-63-40-195.myvzw.com[63.40.195.150]
Feb 24 07:55:53 @A@ postfix/smtps/smtpd[216799]: connect from unknown[102.220.165.187]
Feb 24 07:55:53 @A@ postfix/smtps/smtpd[216799]: SSL_accept error from unknown[102.220.165.187]: lost connection
Feb 24 07:55:53 @A@ postfix/smtps/smtpd[216799]: lost connection after CONNECT from unknown[102.220.165.187]
Feb 24 07:55:53 @A@ postfix/smtps/smtpd[216799]: disconnect from unknown[102.220.165.187] commands=0/0
Feb 24 07:56:02 @A@ postfix/smtps/smtpd[216793]: warning: host150.sub-63-40-195.myvzw.com[63.40.195.150]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 07:56:03 @A@ postfix/smtps/smtpd[216793]: lost connection after AUTH from host150.sub-63-40-195.myvzw.com[63.40.195.150]
Feb 24 07:56:03 @A@ postfix/smtps/smtpd[216793]: disconnect from host150.sub-63-40-195.myvzw.com[63.40.195.150] ehlo=1 auth=0/1 commands=1/2
Feb 24 07:57:47 @A@ postfix/smtps/smtpd[216805]: connect from unknown[5.31.11.154]
Feb 24 07:57:56 @A@ postfix/smtps/smtpd[216805]: warning: unknown[5.31.11.154]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 07:57:57 @A@ postfix/smtps/smtpd[216805]: lost connection after AUTH from unknown[5.31.11.154]
Feb 24 07:57:57 @A@ postfix/smtps/smtpd[216805]: disconnect from unknown[5.31.11.154] ehlo=1 auth=0/1 commands=1/2
Feb 24 07:57:59 @A@ postfix/smtps/smtpd[216805]: warning: hostname 122.248.244.58.adsl-pool.jlccptt.net.cn does not resolve to address 58.244.248.122: Name or service not known
Feb 24 07:57:59 @A@ postfix/smtps/smtpd[216805]: connect from unknown[58.244.248.122]
Feb 24 07:58:08 @A@ postfix/smtps/smtpd[216805]: warning: unknown[58.244.248.122]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 07:58:09 @A@ postfix/smtps/smtpd[216805]: lost connection after AUTH from unknown[58.244.248.122]
Feb 24 07:58:09 @A@ postfix/smtps/smtpd[216805]: disconnect from unknown[58.244.248.122] ehlo=1 auth=0/1 commands=1/2
Feb 24 08:00:31 @A@ postfix/smtps/smtpd[216819]: warning: hostname abts-north-static-216.12.160.122.airtelbroadband.in does not resolve to address 122.160.12.216
Feb 24 08:00:31 @A@ postfix/smtps/smtpd[216819]: connect from unknown[122.160.12.216]
Feb 24 08:00:39 @A@ postfix/smtps/smtpd[216819]: warning: unknown[122.160.12.216]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 08:00:40 @A@ postfix/smtps/smtpd[216819]: lost connection after AUTH from unknown[122.160.12.216]
Feb 24 08:00:40 @A@ postfix/smtps/smtpd[216819]: disconnect from unknown[122.160.12.216] ehlo=1 auth=0/1 commands=1/2
Feb 24 08:00:41 @A@ postfix/smtps/smtpd[216819]: connect from unknown[118.118.234.136]
Feb 24 08:00:52 @A@ postfix/smtps/smtpd[216819]: warning: unknown[118.118.234.136]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 08:00:53 @A@ postfix/smtps/smtpd[216819]: lost connection after AUTH from unknown[118.118.234.136]
Feb 24 08:00:53 @A@ postfix/smtps/smtpd[216819]: disconnect from unknown[118.118.234.136] ehlo=1 auth=0/1 commands=1/2
Feb 24 08:04:13 @A@ postfix/anvil[216792]: statistics: max connection rate 1/60s for (submission:164.215.103.189) at Feb 24 07:55:13
Feb 24 08:04:13 @A@ postfix/anvil[216792]: statistics: max connection count 1 for (submission:164.215.103.189) at Feb 24 07:55:13
Feb 24 08:04:13 @A@ postfix/anvil[216792]: statistics: max cache size 3 at Feb 24 07:55:54
Feb 24 08:06:33 @A@ postfix/smtps/smtpd[216843]: connect from 56.sub-166-148-0.myvzw.com[166.148.0.56]
Feb 24 08:06:42 @A@ postfix/smtps/smtpd[216843]: warning: 56.sub-166-148-0.myvzw.com[166.148.0.56]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 08:06:42 @A@ postfix/smtps/smtpd[216843]: lost connection after AUTH from 56.sub-166-148-0.myvzw.com[166.148.0.56]
Feb 24 08:06:42 @A@ postfix/smtps/smtpd[216843]: disconnect from 56.sub-166-148-0.myvzw.com[166.148.0.56] ehlo=1 auth=0/1 commands=1/2
Feb 24 08:06:45 @A@ postfix/smtps/smtpd[216839]: connect from unknown[203.193.143.46]
Feb 24 08:06:45 @A@ postfix/smtps/smtpd[216839]: SSL_accept error from unknown[203.193.143.46]: lost connection
Feb 24 08:06:45 @A@ postfix/smtps/smtpd[216839]: lost connection after CONNECT from unknown[203.193.143.46]
Feb 24 08:06:45 @A@ postfix/smtps/smtpd[216839]: disconnect from unknown[203.193.143.46] commands=0/0
Feb 24 08:07:11 @A@ postfix/smtps/smtpd[216843]: connect from unknown[220.164.62.174]
Feb 24 08:07:11 @A@ postfix/smtps/smtpd[216843]: SSL_accept error from unknown[220.164.62.174]: lost connection
Feb 24 08:07:11 @A@ postfix/smtps/smtpd[216843]: lost connection after CONNECT from unknown[220.164.62.174]
Feb 24 08:07:11 @A@ postfix/smtps/smtpd[216843]: disconnect from unknown[220.164.62.174] commands=0/0
Feb 24 08:07:15 @A@ postfix/smtps/smtpd[216839]: connect from unknown[194.44.200.98]
Feb 24 08:07:22 @A@ postfix/smtps/smtpd[216839]: warning: unknown[194.44.200.98]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 08:07:22 @A@ postfix/smtps/smtpd[216839]: lost connection after AUTH from unknown[194.44.200.98]
Feb 24 08:07:22 @A@ postfix/smtps/smtpd[216839]: disconnect from unknown[194.44.200.98] ehlo=1 auth=0/1 commands=1/2
Feb 24 08:08:16 @A@ postfix/submission/smtpd[216853]: connect from unknown[164.215.103.189]
Feb 24 08:08:16 @A@ postfix/submission/smtpd[216853]: disconnect from unknown[164.215.103.189] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 24 08:11:36 @A@ postfix/anvil[216845]: statistics: max connection rate 1/60s for (smtps:166.148.0.56) at Feb 24 08:06:35
Feb 24 08:11:36 @A@ postfix/anvil[216845]: statistics: max connection count 1 for (smtps:166.148.0.56) at Feb 24 08:06:35
Feb 24 08:11:36 @A@ postfix/anvil[216845]: statistics: max cache size 2 at Feb 24 08:07:16
Feb 24 08:13:47 @A@ postfix/smtps/smtpd[216873]: connect from unknown[117.158.183.73]
Feb 24 08:18:28 @A@ postfix/smtps/smtpd[216889]: connect from unknown[182.139.39.150]
Feb 24 08:18:40 @A@ postfix/smtps/smtpd[216889]: warning: unknown[182.139.39.150]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 08:18:41 @A@ postfix/smtps/smtpd[216889]: lost connection after AUTH from unknown[182.139.39.150]
Feb 24 08:18:41 @A@ postfix/smtps/smtpd[216889]: disconnect from unknown[182.139.39.150] ehlo=1 auth=0/1 commands=1/2
Feb 24 08:18:42 @A@ postfix/smtps/smtpd[216889]: warning: hostname abts-north-static-184.113.160.122.airtelbroadband.in does not resolve to address 122.160.113.184
Feb 24 08:18:42 @A@ postfix/smtps/smtpd[216889]: connect from unknown[122.160.113.184]
Feb 24 08:18:47 @A@ postfix/smtps/smtpd[216873]: SSL_accept error from unknown[117.158.183.73]: Connection timed out
Feb 24 08:18:47 @A@ postfix/smtps/smtpd[216873]: lost connection after CONNECT from unknown[117.158.183.73]
Feb 24 08:18:47 @A@ postfix/smtps/smtpd[216873]: disconnect from unknown[117.158.183.73] commands=0/0
Feb 24 08:18:51 @A@ postfix/smtps/smtpd[216889]: warning: unknown[122.160.113.184]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 08:18:52 @A@ postfix/smtps/smtpd[216889]: lost connection after AUTH from unknown[122.160.113.184]
Feb 24 08:18:52 @A@ postfix/smtps/smtpd[216889]: disconnect from unknown[122.160.113.184] ehlo=1 auth=0/1 commands=1/2
Feb 24 08:21:10 @A@ postfix/submission/smtpd[216904]: connect from unknown[164.215.103.189]
Feb 24 08:21:10 @A@ postfix/submission/smtpd[216904]: disconnect from unknown[164.215.103.189] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 24 08:24:30 @A@ postfix/anvil[216891]: statistics: max connection rate 1/60s for (smtps:182.139.39.150) at Feb 24 08:18:31
Feb 24 08:24:30 @A@ postfix/anvil[216891]: statistics: max connection count 1 for (smtps:182.139.39.150) at Feb 24 08:18:31
Feb 24 08:24:30 @A@ postfix/anvil[216891]: statistics: max cache size 2 at Feb 24 08:18:44
Feb 24 08:27:34 @A@ postfix/submission/smtpd[216927]: connect from unknown[101.43.13.67]
Feb 24 08:27:35 @A@ postfix/submission/smtpd[216927]: disconnect from unknown[101.43.13.67] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 24 08:30:55 @A@ postfix/anvil[216929]: statistics: max connection rate 1/60s for (submission:101.43.13.67) at Feb 24 08:27:34
Feb 24 08:30:55 @A@ postfix/anvil[216929]: statistics: max connection count 1 for (submission:101.43.13.67) at Feb 24 08:27:34
Feb 24 08:30:55 @A@ postfix/anvil[216929]: statistics: max cache size 1 at Feb 24 08:27:34
Feb 24 08:31:44 @A@ postfix/smtps/smtpd[216947]: connect from unknown[118.41.204.72]
Feb 24 08:31:54 @A@ postfix/smtps/smtpd[216947]: warning: unknown[118.41.204.72]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 08:31:55 @A@ postfix/smtps/smtpd[216947]: lost connection after AUTH from unknown[118.41.204.72]
Feb 24 08:31:55 @A@ postfix/smtps/smtpd[216947]: disconnect from unknown[118.41.204.72] ehlo=1 auth=0/1 commands=1/2
Feb 24 08:32:07 @A@ postfix/smtps/smtpd[216955]: connect from unknown[37.25.36.197]
Feb 24 08:32:07 @A@ postfix/smtps/smtpd[216955]: SSL_accept error from unknown[37.25.36.197]: lost connection
Feb 24 08:32:07 @A@ postfix/smtps/smtpd[216955]: lost connection after CONNECT from unknown[37.25.36.197]
Feb 24 08:32:07 @A@ postfix/smtps/smtpd[216955]: disconnect from unknown[37.25.36.197] commands=0/0
Feb 24 08:32:09 @A@ postfix/smtps/smtpd[216947]: connect from unknown[120.224.15.67]
Feb 24 08:32:09 @A@ postfix/smtps/smtpd[216947]: SSL_accept error from unknown[120.224.15.67]: lost connection
Feb 24 08:32:09 @A@ postfix/smtps/smtpd[216947]: lost connection after CONNECT from unknown[120.224.15.67]
Feb 24 08:32:09 @A@ postfix/smtps/smtpd[216947]: disconnect from unknown[120.224.15.67] commands=0/0
Feb 24 08:32:10 @A@ postfix/smtps/smtpd[216955]: warning: hostname 80-184-100-101.myrepublic.com.sg does not resolve to address 101.100.184.80: Name or service not known
Feb 24 08:32:10 @A@ postfix/smtps/smtpd[216955]: connect from unknown[101.100.184.80]
Feb 24 08:32:19 @A@ postfix/smtps/smtpd[216955]: warning: unknown[101.100.184.80]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 08:32:20 @A@ postfix/smtps/smtpd[216955]: lost connection after AUTH from unknown[101.100.184.80]
Feb 24 08:32:20 @A@ postfix/smtps/smtpd[216955]: disconnect from unknown[101.100.184.80] ehlo=1 auth=0/1 commands=1/2
Feb 24 08:34:09 @A@ postfix/smtps/smtpd[216963]: warning: hostname apzg-0721-a-126.stretchoid.com does not resolve to address 198.199.116.29
Feb 24 08:34:09 @A@ postfix/smtps/smtpd[216963]: connect from unknown[198.199.116.29]
Feb 24 08:34:09 @A@ postfix/smtps/smtpd[216963]: SSL_accept error from unknown[198.199.116.29]: -1
Feb 24 08:34:09 @A@ postfix/smtps/smtpd[216963]: warning: TLS library problem: error:1408F10B:SSL routines:ssl3_get_record:wrong version number:ssl/record/ssl3_record.c:332:
Feb 24 08:34:09 @A@ postfix/smtps/smtpd[216963]: lost connection after CONNECT from unknown[198.199.116.29]
Feb 24 08:34:09 @A@ postfix/smtps/smtpd[216963]: disconnect from unknown[198.199.116.29] commands=0/0
Feb 24 08:35:03 @A@ postfix/submission/smtpd[216966]: connect from unknown[164.215.103.189]
Feb 24 08:35:03 @A@ postfix/submission/smtpd[216966]: disconnect from unknown[164.215.103.189] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 24 08:38:23 @A@ postfix/anvil[216950]: statistics: max connection rate 1/60s for (smtps:118.41.204.72) at Feb 24 08:31:46
Feb 24 08:38:23 @A@ postfix/anvil[216950]: statistics: max connection count 1 for (smtps:118.41.204.72) at Feb 24 08:31:46
Feb 24 08:38:23 @A@ postfix/anvil[216950]: statistics: max cache size 2 at Feb 24 08:32:12
Feb 24 08:39:37 @A@ dovecot[203186]: imap-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=103.203.59.9, lip=00.00.00.00, session=<3W298BoSFqBnyzsJ>
Feb 24 08:44:14 @A@ postfix/smtps/smtpd[217002]: connect from unknown[123.138.101.106]
Feb 24 08:44:23 @A@ postfix/smtps/smtpd[217002]: warning: unknown[123.138.101.106]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 08:44:24 @A@ postfix/smtps/smtpd[217002]: lost connection after AUTH from unknown[123.138.101.106]
Feb 24 08:44:24 @A@ postfix/smtps/smtpd[217002]: disconnect from unknown[123.138.101.106] ehlo=1 auth=0/1 commands=1/2
Feb 24 08:44:25 @A@ postfix/smtps/smtpd[217002]: connect from unknown[14.18.154.85]
Feb 24 08:44:34 @A@ postfix/smtps/smtpd[217002]: warning: unknown[14.18.154.85]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 08:44:35 @A@ postfix/smtps/smtpd[217002]: lost connection after AUTH from unknown[14.18.154.85]
Feb 24 08:44:35 @A@ postfix/smtps/smtpd[217002]: disconnect from unknown[14.18.154.85] ehlo=1 auth=0/1 commands=1/2
Feb 24 08:47:55 @A@ postfix/anvil[217005]: statistics: max connection rate 1/60s for (smtps:123.138.101.106) at Feb 24 08:44:16
Feb 24 08:47:55 @A@ postfix/anvil[217005]: statistics: max connection count 1 for (smtps:123.138.101.106) at Feb 24 08:44:16
Feb 24 08:47:55 @A@ postfix/anvil[217005]: statistics: max cache size 2 at Feb 24 08:44:28
Feb 24 08:49:41 @A@ postfix/submission/smtpd[217023]: connect from unknown[164.215.103.189]
Feb 24 08:49:41 @A@ postfix/submission/smtpd[217023]: disconnect from unknown[164.215.103.189] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 24 08:53:01 @A@ postfix/anvil[217025]: statistics: max connection rate 1/60s for (submission:164.215.103.189) at Feb 24 08:49:41
Feb 24 08:53:01 @A@ postfix/anvil[217025]: statistics: max connection count 1 for (submission:164.215.103.189) at Feb 24 08:49:41
Feb 24 08:53:01 @A@ postfix/anvil[217025]: statistics: max cache size 1 at Feb 24 08:49:41
Feb 24 09:00:13 @A@ postfix/smtps/smtpd[217064]: connect from unknown[117.32.102.90]
Feb 24 09:00:26 @A@ postfix/smtps/smtpd[217064]: warning: unknown[117.32.102.90]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 09:00:27 @A@ postfix/smtps/smtpd[217064]: lost connection after AUTH from unknown[117.32.102.90]
Feb 24 09:00:27 @A@ postfix/smtps/smtpd[217064]: disconnect from unknown[117.32.102.90] ehlo=1 auth=0/1 commands=1/2
Feb 24 09:00:29 @A@ postfix/smtps/smtpd[217064]: connect from 45-161-162-46.suportonlinetelecom.com.br[45.161.162.46]
Feb 24 09:00:37 @A@ postfix/qmgr[202820]: 1B9A610012B: from=<tester01@A2@>, size=550, nrcpt=1 (queue active)
Feb 24 09:00:37 @A@ postfix/qmgr[202820]: 4AA1810017A: from=<tester01@A2@>, size=521, nrcpt=1 (queue active)
Feb 24 09:00:38 @A@ postfix/smtp[217075]: connect to reception.mail-tester.com[94.23.206.89]:25: No route to host
Feb 24 09:00:38 @A@ postfix/smtp[217075]: 1B9A610012B: to=test-zleurf7g1@srv1.mail-tester.com, relay=none, delay=42502, delays=42502/0.05/0.18/0, dsn=4.4.1, status=deferred (connect to reception.mail-tester.com[94.23.206.89]:25: No route to host)
Feb 24 09:00:38 @A@ postfix/smtps/smtpd[217064]: warning: 45-161-162-46.suportonlinetelecom.com.br[45.161.162.46]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 09:00:38 @A@ postfix/smtp[217076]: connect to gmail-smtp-in.l.google.com[142.250.145.27]:25: No route to host
Feb 24 09:00:38 @A@ postfix/smtp[217076]: connect to gmail-smtp-in.l.google.com[2a00:1450:4013:c14::1b]:25: Network is unreachable
Feb 24 09:00:38 @A@ postfix/smtp[217076]: connect to alt1.gmail-smtp-in.l.google.com[2a00:1450:4010:c1c::1b]:25: Network is unreachable
Feb 24 09:00:38 @A@ postfix/smtp[217076]: connect to alt1.gmail-smtp-in.l.google.com[142.250.150.26]:25: No route to host
Feb 24 09:00:38 @A@ postfix/smtp[217076]: connect to alt2.gmail-smtp-in.l.google.com[74.125.200.27]:25: No route to host
Feb 24 09:00:38 @A@ postfix/smtp[217076]: 4AA1810017A: to=tester02@gmail.com, relay=none, delay=42447, delays=42447/0.05/0.72/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[74.125.200.27]:25: No route to host)
Feb 24 09:00:39 @A@ postfix/smtps/smtpd[217064]: lost connection after AUTH from 45-161-162-46.suportonlinetelecom.com.br[45.161.162.46]
Feb 24 09:00:39 @A@ postfix/smtps/smtpd[217064]: disconnect from 45-161-162-46.suportonlinetelecom.com.br[45.161.162.46] ehlo=1 auth=0/1 commands=1/2
Feb 24 09:02:14 @A@ postfix/submission/smtpd[217082]: connect from unknown[164.215.103.189]
Feb 24 09:02:14 @A@ postfix/submission/smtpd[217082]: disconnect from unknown[164.215.103.189] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 24 09:05:34 @A@ postfix/anvil[217067]: statistics: max connection rate 1/60s for (smtps:117.32.102.90) at Feb 24 09:00:15
Feb 24 09:05:34 @A@ postfix/anvil[217067]: statistics: max connection count 1 for (smtps:117.32.102.90) at Feb 24 09:00:15
Feb 24 09:05:34 @A@ postfix/anvil[217067]: statistics: max cache size 2 at Feb 24 09:00:31
Feb 24 09:06:14 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed (no auth attempts in 1 secs): user=<>, rip=35.202.9.133, lip=00.00.00.00, TLS: Connection closed, session=<i8HoTxsSoMcjygmF>
Feb 24 09:17:58 @A@ postfix/smtps/smtpd[217139]: warning: hostname cisco2600.padi.net.id does not resolve to address 202.6.232.126: Name or service not known
Feb 24 09:17:58 @A@ postfix/smtps/smtpd[217139]: connect from unknown[202.6.232.126]
Feb 24 09:18:06 @A@ postfix/smtps/smtpd[217139]: warning: unknown[202.6.232.126]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 09:18:07 @A@ postfix/smtps/smtpd[217139]: lost connection after AUTH from unknown[202.6.232.126]
Feb 24 09:18:07 @A@ postfix/smtps/smtpd[217139]: disconnect from unknown[202.6.232.126] ehlo=1 auth=0/1 commands=1/2
Feb 24 09:18:12 @A@ postfix/smtps/smtpd[217139]: connect from unknown[117.186.145.98]
Feb 24 09:18:14 @A@ postfix/smtps/smtpd[217139]: SSL_accept error from unknown[117.186.145.98]: lost connection
Feb 24 09:18:14 @A@ postfix/smtps/smtpd[217139]: lost connection after CONNECT from unknown[117.186.145.98]
Feb 24 09:18:14 @A@ postfix/smtps/smtpd[217139]: disconnect from unknown[117.186.145.98] commands=0/0
Feb 24 09:18:18 @A@ postfix/smtps/smtpd[217139]: connect from unknown[111.23.117.97]
Feb 24 09:18:28 @A@ postfix/smtps/smtpd[217139]: warning: unknown[111.23.117.97]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Feb 24 09:18:30 @A@ postfix/smtps/smtpd[217139]: lost connection after AUTH from unknown[111.23.117.97]
Feb 24 09:18:30 @A@ postfix/smtps/smtpd[217139]: disconnect from unknown[111.23.117.97] ehlo=1 auth=0/1 commands=1/2
Feb 24 09:20:01 @A@ postfix/submission/smtpd[217151]: connect from unknown[101.43.13.67]
Feb 24 09:20:02 @A@ postfix/submission/smtpd[217151]: disconnect from unknown[101.43.13.67] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 24 09:23:22 @A@ postfix/anvil[217142]: statistics: max connection rate 1/60s for (smtps:202.6.232.126) at Feb 24 09:18:00
Feb 24 09:23:22 @A@ postfix/anvil[217142]: statistics: max connection count 1 for (smtps:202.6.232.126) at Feb 24 09:18:00
Feb 24 09:23:22 @A@ postfix/anvil[217142]: statistics: max cache size 2 at Feb 24 09:18:20
Feb 24 09:23:23 @A@ dovecot[203186]: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=66.240.192.138, lip=00.00.00.00, session=<9bdAjRsSjI5C8MCK>
Feb 24 09:23:23 @A@ dovecot[203186]: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=66.240.192.138, lip=00.00.00.00, session=<sRhIjRsS6o9C8MCK>
Feb 24 09:23:24 @A@ dovecot[203186]: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=66.240.192.138, lip=00.00.00.00, session=<V09OjRsSdJBC8MCK>
Feb 24 09:23:24 @A@ dovecot[203186]: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=66.240.192.138, lip=00.00.00.00, session=<EsNUjRsSIpFC8MCK>
Feb 24 09:23:25 @A@ dovecot[203186]: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=66.240.192.138, lip=00.00.00.00, session=<ukhbjRsS5pFC8MCK>
Feb 24 09:23:25 @A@ dovecot[203186]: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=66.240.192.138, lip=00.00.00.00, session=<T75hjRsSbJJC8MCK>
Feb 24 09:23:26 @A@ dovecot[203186]: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=66.240.192.138, lip=00.00.00.00, session=<Jx5ojRsSEJNC8MCK>
Feb 24 09:23:26 @A@ dovecot[203186]: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=66.240.192.138, lip=00.00.00.00, session=<T11ujRsS7pNC8MCK>
Feb 24 09:23:26 @A@ dovecot[203186]: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=66.240.192.138, lip=00.00.00.00, session=<ixJ1jRsSmJVC8MCK>
Feb 24 09:23:27 @A@ dovecot[203186]: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=66.240.192.138, lip=00.00.00.00, session=<QEx9jRsS1pZC8MCK>
Feb 24 09:23:28 @A@ dovecot[203186]: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol (no auth attempts in 1 secs): user=<>, rip=66.240.192.138, lip=00.00.00.00, TLS handshaking: SSL_accept() failed: error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol, session=<6UeKjRsSGJhC8MCK>
