Plugin doesn't work anymore for me. On settings appear all fileds "undefinied"
If i launch a cron have this:
File "/www/server/panel/plugin/aws_s3/aws_s3_main.py", line 24, in <module>
from s3lib.client.aws_s3 import COSClient
File "/www/server/panel/plugin/aws_s3/s3lib/client/aws_s3.py", line 22, in <module>
from boto3 import client
File "/www/server/panel/pyenv/lib/python3.7/site-packages/boto3/init.py", line 17, in <module>
from boto3.session import Session
File "/www/server/panel/pyenv/lib/python3.7/site-packages/boto3/session.py", line 17, in <module>
import botocore.session
File "/www/server/panel/pyenv/lib/python3.7/site-packages/botocore/session.py", line 26, in <module>
import botocore.client
File "/www/server/panel/pyenv/lib/python3.7/site-packages/botocore/client.py", line 15, in <module>
from botocore import waiter, xform_name
File "/www/server/panel/pyenv/lib/python3.7/site-packages/botocore/waiter.py", line 18, in <module>
from botocore.docs.docstring import WaiterDocstring
File "/www/server/panel/pyenv/lib/python3.7/site-packages/botocore/docs/init.py", line 15, in <module>
from botocore.docs.service import ServiceDocumenter
File "/www/server/panel/pyenv/lib/python3.7/site-packages/botocore/docs/service.py", line 14, in <module>
from botocore.docs.client import ClientDocumenter, ClientExceptionsDocumenter
File "/www/server/panel/pyenv/lib/python3.7/site-packages/botocore/docs/client.py", line 14, in <module>
from botocore.docs.example import ResponseExampleDocumenter
File "/www/server/panel/pyenv/lib/python3.7/site-packages/botocore/docs/example.py", line 13, in <module>
from botocore.docs.shape import ShapeDocumenter
File "/www/server/panel/pyenv/lib/python3.7/site-packages/botocore/docs/shape.py", line 19, in <module>
from botocore.utils import is_json_value_header
File "/www/server/panel/pyenv/lib/python3.7/site-packages/botocore/utils.py", line 37, in <module>
import botocore.httpsession
File "/www/server/panel/pyenv/lib/python3.7/site-packages/botocore/httpsession.py", line 22, in <module>
from urllib3.util.ssl_ import (
ImportError: cannot import name 'DEFAULT_CIPHERS' from 'urllib3.util.ssl' (/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/ssl.py
Any Idea? I have reinstalled the plugin, but no result.
Piero
