Same issue here...Can anyone please help ?
9 days later
edit /www/server/panel/install/php.sh
find version == 8.3 , add --enable-mbstring following —enable-mysqlnd
save
reinstall
bash /www/server/panel/install/php.sh install 8.3
    5 months later
    The mbstring extension is not available with Ubuntu 20.04.6 LTS x86_64, PHP 8.3.
    Panel version: 7.0.6
    a month later
    can confirm, not posible to install right now:
    https://na1-node.bt.cn
    selecting download node...
    PHP Warning: PHP Startup: Unable to load dynamic library 'mbstring' (tried: /www/server/php/83/lib/php/extensions/no-debug-non-zts-20230831/mbstring (/www/server/php/83/lib/php/extensions/no-debug-non-zts-20230831/mbstring: cannot open shared object file: No such file or directory), /www/server/php/83/lib/php/extensions/no-debug-non-zts-20230831/mbstring.so (/www/server/php/83/lib/php/extensions/no-debug-non-zts-20230831/mbstring.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
    mbstring.sh: line 46: cd: /www/server/php/83/src/ext/mbstring: No such file or directory
    Cannot find config.m4.
    Make sure that you run '/www/server/php/83/bin/phpize' in the top level source directory of the module
    mbstring.sh: line 48: ./configure: No such file or directory
    error
      10 days later
      I have the same problem, I can't install any extension.
      VPS with Ubuntu 24.04
      Nginx 1.24.0
      PHP-8.3
      Intel(R) Xeon(R) Gold 6138 CPU @ 2.00GHz * 2 CPU
      2GB RAM
        5 days later
        aaPanel_Kern aaPanel_Kern
        with default compilation not posible to add other modules i need, memcahe for example.
        Why its so unfriendly?
        Why dont add 20 checkmarks to allow user to select what modules it need during compilation!
        This checkmarks can auto add --enable-memchas or --with-optcahe, examples.
        I thought pannel can save my time but i spent 8h to make php project to work, faced 20+ bugs, i could do all this from 0 with bash in 3h.
        And btw, 16 days from my report about simple issue "No such file or directory" is this issue allready fixed? I think its not.
        8 days later
        Hi anyone available
        please help me i have same issue in my aapanel i install mbstring first from the ubuntu terminal but it does'nt work
        error like this (PHP Warning: Module "zip" is already loaded in Unknown on line 0)
        so i landed this post and find i also do from the php extension i click on the install button but its only processing not worked i click 3 times it dowsn;'t work please help me i have 2 websites and still the issue is not solved
        https://vaultapk.com
        also i reinstall my PHP8.3 then in the execution log error i checked (
        Hello, this configuration will not affect the use. You can also add a # comment to the zip.so at the end of the configuration file.
        Please check the specific error reason: /tmp/panelExec.log
        aaP_hk2263247
          you mean add the # in the PHP configuration at the end of the file zip.so right?
          i execute this in terminal that you give me /tmp/panelExec.log
          result: -bash: /tmp/panelExec.log: Permission denied
            please check this
            i install these files
            but there not installing ?
            $PHP_AUTOCONF environment variable. Then, rerun this script.
            fileinfo.sh: line 93: ./configure: No such file or directory
            sed: can't read Makefile: No such file or directory
            error
