aaPanel_Kern Hello, please use a new server to install aawaf. Port 80 443 is already in use and installation is not supported. aaP_marian007p
aaP_marian007p But I have already websites and databases on this server and I can't use new server. There is any workaround?
aaPanel_Kern The web server does nothing; just install aawaf on a new server and follow the tutorial to configure it aaP_marian007p
aaP_marian007p New server new cost. What if I remove the above ports, install aaWAF and add again these ports after instalation is done?
aaPanel_Kern For those using aapanel, use the app store's nginx waf and apache waf A port can only use one service
aaP_marian007p @aaPanel_Kern You say that aaWAF should be installed on a different server, other than where aapanel is installed?
aaP_marian007p Oh !!! Now I have both installed on the same server. 🙁 @aaPanel_Kern how to remove aaWAF from actual server?
