syarfandi Please help, I can't open the panel right after installing aapanel, even though I installed it on a clean OS and opened all the required ports.
aaPanel_Kern Hello, what message does it display when it cannot be opened? Whether the bt service is started: bt status syarfandi
syarfandi aaPanel_Kern it says "ERR_CONNECTION_TIMED_OUT, This site can’t be reached, took too long to respond." bt status : Bt-Panel (pid 8345) already running Bt-Task (pid 8364) already running
aaPanel_Kern It is recommended that you check whether the system firewall and server security group have relevant ports open? Also check whether the relevant ports are in normal use? syarfandi
