Hi @aaPanel_Kern kindly help me to fix this issue.
I Installed WordPress In the Laravel application.
sub.domain.com/public/blog
My config code:
`server
listen 80;
listen 443 ssl http2;
server_name sub.domain.com www.sub.domain.com.com;
root /www/wwwroot/sub.domain.com.com/public;
#error_page 404/404.html;
#HTTP_TO_HTTPS_START
if ($server_port !~ 443){
rewrite ^(/.*)$ https://$host$1 permanent;
#HTTP_TO_HTTPS_END
ssl_certificate /www/server/panel/vhost/cert/sub.domain.com.com/fullchain.pem;
ssl_certificate_key /www/server/panel/vhost/cert/sub.domain.com.com/privkey.pem;
ssl_prefer_server_ciphers on;
ssl_session_timeout 10m;
#SSL-END
#error_page 404 /404.html;
#error_page 502 /502.html;
#ERROR-PAGE-END
include enable-php-81.conf;
#PHP-INFO-END
include /www/server/panel/vhost/rewrite/sub.domain.com.conf;
#REWRITE-END
# removes trailing slashes (prevents SEO duplicate content issues)
if (!-d $request_filename)
rewrite ^/(.+)/$ /$1 permanent;
# enforce NO www
if ($host ~* ^www\.(.*))
set $host_without_www $1;
rewrite ^/(.*)$ $scheme://$host_without_www/$1 permanent;
# unless the request is for a valid file (image, js, css, etc.), send to bootstrap
if ($request_uri ~* "^(.*/)index\.php$") {
return 301 $1;
if (!-e $request_filename)
rewrite ^/(.*)$ /index.php?/$1 last;
break;
location ^~ /storage/ {
location / {
try_files $uri $uri/ /index.php?$query_string;
location ^/blog/index.php(/.*)?$ {
fastcgi_split_path_info ^(/blog/index.php)(/.+)$;
location /blog/ {
if (!-e $request_filename) {
rewrite ^.*$ /blog/index.php last;
location ~* \.php$ {
try_files $uri = 404;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass unix:/var/run/php8.1fpm.sock; # may also be: 127.0.0.1:9000;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
include fastcgi_params;
location ~ /\.ht {
deny all;
location ~ ^/(\.user.ini|\.htaccess|\.git|\.env|\.svn|\.project|LICENSE|README.md)
return 404;
location ~ \.well-known{
allow all;
#Prohibit putting sensitive files in certificate verification directory
if ( $uri ~ "^/\.well-known/.*\.(php|jsp|py|js|css|lua|ts|go|zip|tar\.gz|rar|7z|sql|bak)$" ) {
return 403;
expires 30d;
error_log /dev/null;
access_log off;
location ~ .*\.(js|css)?$
expires 12h;
access_log off;
access_log /www/wwwlogs/sub.domain.com.log;
error_log /www/wwwlogs/sub.domain.com.error.log;
it is working fine
sub.domain.com/blog/
but when clicking on Post or Page
https://sub.doman.com/blog/far-far-away-behind-the-word-mountains/
404 error shows
kindly guide me to fix it. Thanks
